6.0 engine dies out - Ford Powerstroke Diesel Forum
post #1 of 29 Old 01-30-2008, 04:55 PM Thread Starter
Send a message via Yahoo to kittcarson_99
Question 6.0 engine dies out
Recently my 6L F250 dies running down the road. Sometimes it will start right back up and sometimes i have to wait for a few minutes. Getting a P2285 code. Have had the engine light on for a while with this code. It started right after i had the connector replaced on the ICP sensor. Through my research it seams it may be a bad Cam possition sensor or the ICP may be going bad. (Note: I did not replace the sensor, just the melted trough plug going into it.) Thinking about replacing one or both of these may solve the problem, but I'm looking for some pro's to point me in the right direction. Thanks for any help you can give me...
Still alive and kicking!
kittcarson_99 is offline
post #2 of 29 Old 01-30-2008, 05:05 PM
Desert Shield/Storm Vet
vitalidle's Avatar
Usually the cps isn't an issue with the 6.0. Im not sure what it could be Im sure one of the techs will see this thread
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #3 of 29 Old 01-30-2008, 05:10 PM
Send a message via MSN to bryan70546 Send a message via Yahoo to bryan70546
did you see my org sticker on the back of my truck . lol nice to see another stroker from lake charles. WELCOME TO THE ORG . hope you get your problem fixed. maybe I will see you around .
2004 6.0 4door SWB lariat BUILD DATE
09/05/2003
ZooDad Mod Custom seat covers .4" duels with 6" tips no kitty ,no muffler .Issapro Boost , Trans temp , pyro .S&B Intake . Accufab intake elbow.Tow Mirrors installed finally, EGR Delete
2008 Yamaha Bigbear 400 with ITP mudlites & ITP ss12s . 2007 Yamaha 700 FI Raptor LTE duels ,GYRT intake and filter Dobeck powercommander 2.
2008 Yamaha R6 Raven
bryan70546 is offline
post #4 of 29 Old 01-30-2008, 05:27 PM Thread Starter
Nice to see someone close by. Usually find me somewhere between Mississipi and west Texas.( Did a California run a few weeks back) I do about 120K a year miles with this hotshot thing, but I'll be around. Catch you on the other side.
post #5 of 29 Old 01-30-2008, 05:34 PM
Right on brother be safe out thier.
09/05/2003
post #6 of 29 Old 02-01-2008, 10:13 AM Thread Starter
Might have found solution... Plugged it in today and found the EGR was fouled. Pulled it and cleaned it. Cheap fix for now but it might still need to be replaced. Also got 3 codes for the ICP. I'm going to leave the ICP alone for now, It's a pain to replace and the truck is still running. I'll probobly do the ICP when the weather straitens back out down here.
post #7 of 29 Old 02-01-2008, 10:18 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 25 Post(s)
If your ICP is bad, you may be replacing the wire harness again as well...if its leaking oil. So my suggestion would be to not wait on replacing it and see if its leaking oil. that wire harness was quite expensive from what i remember.
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #8 of 29 Old 02-01-2008, 10:22 AM Thread Starter
Just replaced the harness 6 months ago. Just going to wait untill my yard is not knee deep in mud. Had to put 40 Cubic yards of crushed concrete in just to get to my shop.
post #9 of 29 Old 02-01-2008, 10:32 AM
bfloyd4445's Avatar
Quoted: 3 Post(s)
isn't there an egr delete mod that increases power and fuel economy for the 6.0?
Britt
2007 F250 CC SB 4X4, SB, PSD, Lariet, stock
1975 Ford 2000 ROP Diesel tractor < ran without oil for 2/10 mile 7/12/2009> Stills runs as good as ever
"If you don't read the newspaper you are uninformed,
If you do read the newspaper you are misinformed."
-Mark Twain
bfloyd4445 is offline
post #10 of 29 Old 02-01-2008, 10:36 AM Thread Starter
Yes but for now I'm keeping mine intact. I have to pass D.O.T. inspections regularly. I run Hotshot and while not every state enforces this I am trying to stay legal for the long runs.(California, Washington, etc...)
