2004 6.0 Powerstroke running rough - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-01-2013, 05:29 PM Thread Starter
I'm new to the forum so forgive me if this question has been asked by others. I hooked up my Superchips module to check the dtc codes and I'm getting a p0282 and p0611. It says the p0282 is the #8 injector and p0611 is the FICM. I saw a video on youtube showing how to test the FICM so I did that. I have the one with 4 terminals. With the ignition on it reads 47.8 volts and at idle reads 45.7. According to the video it should be 48 and above 45 respectively. How can I determine if the FICM is the problem and/or if I have injector problems? Any guidance is appreciated.
Truck has 128k miles and had the HPOP replaced last year.
mlibner is offline
post #2 of 4 Old 04-01-2013, 05:33 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
To really check the FICM, you need to check the voltage while cranking the engine. As far as the injector code, you can wiggle the connector and see if it does anything. Unless you have Auto Enginuity or something similar, you would have to take it to a dealerahip and have a buzz test and contribution/power balance test performed.
dhanna6powerstroke is offline
post #3 of 4 Old 04-01-2013, 05:38 PM Thread Starter
Thanks for the quick reply. In order to do that what do I need to do to prevent the engine from starting and what should the reading be?
mlibner is offline
post #4 of 4 Old 04-01-2013, 05:42 PM Thread Starter
Sorry didn't see the rest of your post. Thanks for the info.
mlibner is offline
