06 6.0l fuel problems - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-01-2013, 04:22 AM Thread Starter
Ok I have a 06 with 123, 000 miles. Friday I changed oil and fuel filters, took off and didn't make it a mile and it sputtered to a stop and didn't want to start. Cycled key several times and after cranking numerous times it finally started. Well made it about a mile and it did the same thing. This happened once more and it continued to run, but everytime I would start to give it a little extra throttle such as going up on ramp it started chugging like it was starved for fuel, if I would cut back it woukd clear up. After dinner it did this same thing when I fueled on it hard, it ended up quitting this time and not restarting, I coukd hear the fuel pump cycling but it did not sound normal. Could I please have some help here. Thank u
06 F250 CC SWB FX4 Lariat, Blue spring kit, 4" MBRP turbo back exhaust, Isspro guages, SRL from Gearhead
, Now if i can just find that money tree out back
kyvfrer is offline
post #2 of 9 Old 04-01-2013, 05:45 AM
BigDogOil's Avatar
Take the fuel filter cap off that is on the engine and cycle the key to see if there is fuel filling the bowl. If not probably the pump, if it is then your going to have to go deeper into the problem.
2012 F 350 Lariat 4X4 Crew Cab SRW
EGR Delete
DPF Delete
SCT Tuner
SOLD:2004 F 350 XLT 4X4 Crew Cab SRW
SCT Programmer
ScanGauge II
GlowShift Pillar Mount & Gauges
Upgrade Fuel Regulator
6.4 Bango Bolts
EGR Delete
Coolant Filter by Me
ELC Coolant
High Idle Mod
Zoodad Mod
BigDogOil is offline
post #3 of 9 Old 04-01-2013, 05:48 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 548 Post(s)
Garage
Did you use a Motorcraft filter and the oem cap ?
Do you have a ScanGaugeII or any type of monitoring ??
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
4" SS exhaust
58K Miles on it
2000 Watts of McIntosh Bliss
mhatlen is online now
post #4 of 9 Old 04-01-2013, 05:49 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
Motorcraft filters? Both caps on tight? No double o ring? Crack a cap? I bet it's something small. Drain water separator and check for leaks and both caps tight loosen top cap cycle key to prime and get air out.
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx custom tuned, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Lighting, No Limit S2 Intake, Tinted, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #5 of 9 Old 04-01-2013, 07:46 AM Thread Starter
Thanks guys, yeah I always use motorcraft filters. Havent noticed any leaks but did notice the bottom filter did not want to pop into place as easily as before. This eveni g I will pull the top cap and go from there. Hoping it is just getting air from somewhere. Definately a love hate relationship
kyvfrer is offline
post #6 of 9 Old 04-02-2013, 05:11 AM
Quoted: 7 Post(s)
did you have any luck?
post #7 of 9 Old 04-03-2013, 04:05 AM Thread Starter
Woohoo she is running like a champ. Thanks so much for the advice and info, exactly why I love the org!!! I pulled the bottom filter cap and the oring fell out in two pieces, put new one in and purges the system, bam she is running. Thanks again guys for all the help
kyvfrer is offline
post #8 of 9 Old 04-03-2013, 04:29 AM
Quoted: 7 Post(s)
no problem man glad it was an easy fix good to hear shes running good.
post #9 of 9 Old 04-03-2013, 05:11 AM Thread Starter
It is paid for but man somedays I just want to give it up for a half ton gas and just drive the freaking thing
kyvfrer is offline
