late 04 wont idle after hpop replacement please help - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-31-2013, 05:39 PM Thread Starter
ok so I just did the hpop oil cooler egr delete stand pipes dummy plugs and ipr valve. I tried and tried to start it but wouldn't fire so I give it a little shot of either and it started up but it will not idle am I missing something here I also changed all filters with the motor craft filters and heading to town in the morning to get a scanner to read live data thanks for any help
dj.oneil is offline
post #2 of 2 Old 03-31-2013, 05:48 PM Thread Starter
o and if it helps any just after I got it started I let it run till my temp was at normal temp and tried to get it to idle but it still wouldn't and I also noticed it spit a little oil from the cold side of the air to air at the top of the motor
dj.oneil is offline
