almost there. please help - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-31-2013, 12:17 PM Thread Starter
Ok. So after replacing basically the entire hpo system to fix my leak. I have finally found my leak. It is at the connection between injector #4 and oil rail. However, since its sunday and I cant get any parts I switched injector 2 and 4 as well as swapping coerresponding nipple and oil rail oring. I did this in hopes that the leak would change to the number 2 position and I would know the soarse of my problem. But guess what???? The leak is STILL at the n7mber 4 injector to oil rail connection. What could it be????
04 (late build) f250 King Ranch CCSB
5 inch TBE, afe intake, egr delete,
ARP head studs
Sold
04 late build cc lb fx4 lariat
4 inch turbo back straight pipe
Airaid intake
Egr delete
notimeforfakes is offline
post #2 of 2 Old 03-31-2013, 01:42 PM Thread Starter
Pressure tested the rail. No leaks. Could the number 4 injector be sitting too low and thats why its not sealing????
ARP head studs
Sold
Airaid intake
Egr delete
