EOT lower then ECT? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 03-31-2013, 12:08 PM Thread Starter
Johnnypsd06's Avatar
EOT lower then ECT?
Hey guys I'm new on this forum and in need of some help!
I have a 2006 psd I have the following done to her
Arp head studs
Powermax turbo
New injectors
Afe intake
Hpop
4" exhaust
Edge cts monitor
The truck runs great but for some reason I'm seeing a lot of weird numbers when fully warmed up
My ect and eots are no more then a couple digits off but then at random the eot drops 15-20 below for a few minutes then up again when I accelerate.
Any ideas???
Thanks guys
Johnnypsd06 is offline
post #2 of 14 Old 03-31-2013, 02:45 PM
is there a tune on it?
smokejoke is offline
post #3 of 14 Old 03-31-2013, 02:48 PM Thread Starter
It's the basic sct X3 towing tune
My pride and joy consist of my Wife, kids, truck, motorcycle and tools
But not in that exact order
post #4 of 14 Old 03-31-2013, 02:59 PM
Switch it back to stock and see if the scan gauge is working correctly. You can also check to see if the scan gauge has the correct program code set in it.
post #5 of 14 Old 03-31-2013, 03:04 PM Thread Starter
Okay thanks ill check that tonight an ill keep and update
Thanks!!
post #6 of 14 Old 04-01-2013, 09:12 AM Thread Starter
Well it still does the same thing
The codes I have are all egr related as I have had it deleted
I also forgot to mention my powermax has a little oil leak would that conflict with anything?
post #7 of 14 Old 04-01-2013, 10:03 AM
Did you check to see if your scan gauge has the right logic/code/setting? Did you buy your scangauge pre loaded with the sttings or did you have to program in the x gauge command codes things?
Ford Specific XGauges : Linear Logic : Home of the ScanGauge
post #8 of 14 Old 04-01-2013, 10:32 AM Thread Starter
How do I tell if it has the right code? It came preloaded. They had it tuned to towing for me when I went to pick it up and the edge cts has been working normal until the problem started a month ago.
Could it be a eot sensor? But it drops when stopped but does come up at acceleration it is still very random when it happens.....
I love my truck, I love my truck, I love my truck..........
post #9 of 14 Old 04-01-2013, 10:39 AM
Adamv7010's Avatar
Maybe its a super oil cooler ha
Try another measurement device. My OTC said my oil temp was 3xx when coolant was correct
Adamv7010 is offline
post #10 of 14 Old 04-01-2013, 11:16 AM
I'm confused, I thought you said you were monitoring with a scangauge
