6.0 shuts down by itself. - Ford Powerstroke Diesel Forum
post #1 of 12 Old 03-31-2013, 11:52 AM Thread Starter
hey guys i just did a coolant flush on my truck i put in some zerex cat-1 coolant. while i was letting it get to temp(probably running maybe 20mins) the truck shut off by itself. i looked at cluster the check gauge light, battery, water in fuel line(not sure if that is what its called) , lights came on. it fired right back up fine but shut off again. any ideas what it could be? i thought the computer needed to be reset so i disconnected the batteries. any help is appreciated.
update: well i drained the water separator dirt and other particles came out of the drain plug and installed a new filter(ford filter) still no change. starts up then runs for a few seconds then cuts out again. when the trucks runs it sounds boggy is best way to describe it. i put some diesel kleen in the tanks but i doubt that it helped any.
Its neither good nor bad, only thinking it makes it good or bad.
UserError is offline
post #2 of 12 Old 04-01-2013, 07:49 PM Thread Starter
bumpski the truck runs then shuts down WIF light comes on i tried draining the separator still no change.
post #3 of 12 Old 04-01-2013, 07:58 PM
WEWILLE's Avatar
What kind of scan tool access do you have?
How is the oil level, how easily does it resrart?
ASE Certified Master Automotive/light duty truck Technician
ASE light diesel specialist
Ford Certified Diesel Technician
Isuzu Certified Gas/Diesel Technician
2007 F-250 PSD FX4 crew cab shortbox king ranch
2005 F-250 PSD FX4 crew cab short Box burned up
2013 Fusion 1.6L Ecoboost
2011 Ford Edge
1999 Dodge 2500 Cummins
WEWILLE is offline
post #4 of 12 Old 04-01-2013, 08:00 PM Thread Starter
I can get my hands on OTC(i thinks that is the name) scan tool from a mechanic at work i work at a GM dealership.
post #5 of 12 Old 04-02-2013, 03:13 PM Thread Starter
well i got my hands a scan tool the OTC Nemisys. i got the following codes.
P0046-turbo bypass valve control circuit range/performance
P0603-internal control module kam error
P0672-glow plug circuit 2
P0678-glow plug circuit 8
P2614-camshaft position output circuit/open
P2617-crankshaft position output circuit/open
i cleared the codes scanned it again and last two codes P2614, P2617 did not show up again. i tried to start start it again and it still ran for a second then cut out again.
post #6 of 12 Old 04-02-2013, 03:20 PM Thread Starter
oil level good restarts easy just won't stay running.
post #7 of 12 Old 04-02-2013, 03:26 PM
PHYRMN's Avatar
You need a scan tool like a scanguage to check a few PID's like:
FICM Voltage
IPR
ICP
Here is some good reading, it will help alot with the diagnosis.
No start issue? Look here.
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #8 of 12 Old 04-02-2013, 04:36 PM Thread Starter
FICM Voltage
IPR
ICP
i was going though the link you provided. i went back and double checked the chaffing areas and found that i must have broke the connector that goes to the vgt solenoid. can i correctly assume that this is the problem causing it to run then shut down?
post #9 of 12 Old 04-02-2013, 04:52 PM
PHYRMN's Avatar
I wouldn't think that a non functional VGT would cause a no start or die at idle. I would think that it would more than likely cause a lack of power issue. Code P0046 is set when a short to ground, open, or short to power is identified in the VGT circuit or wiring between the PCM and VGT.
PHYRMN is offline
post #10 of 12 Old 04-03-2013, 03:55 AM
WEWILLE's Avatar
Just for kicks unplug the ebp sensor...
2011 Ford Edge
WEWILLE is offline
