2003 6.0 will not start. - Ford Powerstroke Diesel Forum
post #1 of 15 Old 01-29-2008, 03:59 PM Thread Starter
scottycal's Avatar
I have a 2003 F350 6.0 4x4 daully. It has 200,000 miles and is always looked after. I tried to start it after a long drive, but it just cranked over. I checked the batteries, no problems. Checked the fuel pump, no problem. I called the Ford dealer and was told it had a bad oil pump, not enough pressure. I then changed the oil pump and both oil presure lines to the injectors. Still would not start I had a mechanic run a diagnostic test with the computer scope,there where a few codes that showed nothing to do with the starting problem. I then installed new O rings on all the injectors, still will not start. I have done everything but rebuil the motor. Can some one help.
scottycal is offline
post #2 of 15 Old 01-29-2008, 04:01 PM
what were the codes?? How cold is it where you are?? have you tested the glow plug system?? how long did you crank it after the injector replacement...it can take a few cranking cycles to get them to fire.....
are you positive you have good fuel pressure??
mschn99 is offline
post #3 of 15 Old 01-29-2008, 04:56 PM Thread Starter
scottycal's Avatar
Hi Marc,
I am in Southern California, temp is 55 dgrees, we have tested the glow plugs ,they are OK. We hooked up 2 battery chargers and cranked every 30 mins for most of the day. Fuel pressure is very good. P0480 and P0649 are the codes.
Thanks
post #4 of 15 Old 01-29-2008, 05:06 PM
97powerstroker's Avatar
do a compression test,if there isnt enough ,it wont start.
96 F250 460-auto-ext.cab-long box-4.10-152k-10mpg all day running or not.....
97powerstroker is offline
post #5 of 15 Old 01-29-2008, 05:12 PM
do you have any way to monitor the ICP??
mschn99 is offline
post #6 of 15 Old 01-30-2008, 09:09 AM
npccpartsman's Avatar
Quoted: 5 Post(s)
P0480--fan control circuit P0649--cruise control lamp circuit
Are you getting any smoke as you crank? Does the oil gauge on the dash come up to pressure? Which oil pump did you replace--low pressure or high pressure?
I Bleed Razorback Red
Ford Makes It, International Shakes It, Casserly Fuels It, KC Turbo Spools It, SCT Tunes It, and Trucks Unlimited keeps her Rockin the Road
npccpartsman is offline
post #7 of 15 Old 01-30-2008, 09:32 AM
Farmerjohn's Avatar
Send a message via AIM to Farmerjohn Send a message via Yahoo to Farmerjohn
I had this problem last week, I had to replace the IPR not enough oil pressure to start, I only had 250lbs, you need to monitor the Icp, when it starts it should jump up to about 2000, I do believe but could be wrong.
Farmerjohn is offline
post #8 of 15 Old 01-30-2008, 04:44 PM Thread Starter
scottycal's Avatar
2003 F350 6.0
I replaced high pressure oil pump. The gauges reads high pressure. No smoke when cranking. I am now check the electrical system.
post #9 of 15 Old 01-30-2008, 04:45 PM
To start you need at least 350-400 psi icp to start. Sounds like maybe a injector is leaking. If the problem is icp. But if it was icp it should throw a code unless there is a wiring problem to the ipr. An open curcuit to the ipr wont throw a code. Double check fuel pressure first.
Certified International Tech unfortunatly specializing in the VT365(6.0 power stroke) engine. I'm here to help those people(as much as I can) that are lucky enough to have this in a light duty and not a medium duty truck.
bigbomar4 is offline
post #10 of 15 Old 01-30-2008, 05:10 PM Thread Starter
scottycal's Avatar
We have more than 500 PSI, removed all injectors and installed new O rings. Fuel pressure is good. Replaced high pressure oil lines to injectors.
