Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Motor problems
Old 08-13-2005, 05:49 PM
ed g ed g is offline
6.0 diesel multitude of problems
2004 Lariet CC dually
vibration in engine at 1500 and 2100 rpms, ford calls it a drone in the engine, engineers sent three different brackets to go between the turbo and manifold,
no fix, engine looses rpm and starts smoking and finally picks back, had new egr valve and wiring modification, no help, never know when it is going to do it, gets 9 miles to gallon, ford can't fix, not covered under lemon law because it is over ten thousand pounds so you buy it, you are stuff with it, any suggestions other than a stick of dynamite.
Thanks, Ed
Old 08-14-2005, 08:27 AM
Rodslinger Rodslinger is offline
Gun Nut
Man Ed, sure sounds like you got a serious lemon. Have you talked to them about a buy back?
Old 10-04-2005, 07:44 PM
StrokedByPowerStroke StrokedByPowerStroke is offline
Angry I have a 2004 also..
My 04 is stock @ 3000mile it blew up the top end and we were babing this thing. Ford kept it for almost 4 week. Wouldn't do anything,but fix-it. It gets about 9-12 mpg. If i'm towing 2 quads on trailier about 1500-2000 lbs. go thru Colorado I was getting as low as 6 mpg. Runs bads since new. Reprogrammed it about 7-8 times still runs like CRAP. It dies while drive down steel hills, Cruise control shuts off while goning down the road for no reason. The dealer ship told me that they cured all 6.0 problems before I bought it.
Old 10-04-2005, 08:09 PM
6.0 shut down
disconnect EGR valve and try it, mine was doing same thing, hasn't shut down in a month
Old 10-30-2005, 08:11 PM
Ramsmoker Ramsmoker is offline
Powerstroke Techie
Cool Lemon
Check the law's in your state. In my state after 3 attemps you get a new rig. I did it in 96 and got a new 97!!! Fords not hurt'n and for your outlay of cash, you shouldn't be.
Old 05-27-2007, 04:14 AM
mrnecsteve mrnecsteve is offline
Try a differant dealership/mechanic. I have been in the service business for better than 30 years (computers) Some techs are simply not that good at diagnosing and troubleshooting. If i were to guess as to the fault,the turbo is not varying output correctly.
A worthwhile article.
http://www.forddoctorsdts.com/articl...icle-05-02.php called
Critical Technician Shortage?
Old 05-27-2007, 09:25 AM
jphelzer jphelzer is offline
FDDTS - Critical Technician Shortage called
Sorry to but that is a cool website actually. Check out the photographs. They show common wiring, engine, turbo and other issues. Pretty slick.
Ford Doctors Diesel Technician Society
