6.0 intermittent boost issue - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-30-2013, 01:09 AM Thread Starter
Hi there,
Got a 2005 6.0 with an intermittent boost issue this only happens once in a while but is normally ok. My truck is as follows
2005 6.0
Arp studs
Egr delete
Oil cooler etc
Livewire ts (Canned tunes at the moment to elimate that it wasn't a problem with tune)
So basically what happens you are going along at 50mph you then want to punch it (WOT) the turbo doesn't spool stays at 0psi and just blows loads of black smoke. If you roll into the power it's normally ok, it doesn't do this all the time just sometimes. I also had it where I was at a light and went WOT to 85mph then let off and went to get back on the power and there was no psi and black smoke.
I had the bulletproofing done just over a month ago, it's not throwing any codes and I have checked for boost leaks. From reading online I think it may be sticking vanes in the turbo??
Any help or advise is greatly welcomed!
Phi1 is offline
post #2 of 5 Old 03-30-2013, 12:28 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
Yes, that sounds like sticking vanes in your turbo.
Did you have it bulletproofed because of a bad egr cooler or headgaskets? I ask this because if you did then your turbo sticking is from having coolant blow through the turbo causing excessive rusting and corrosion.
My turbo started doing the same thing shortly after my egr cooler was replaced because of leaking. So the turbo was replaced next and solved the issue!
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #3 of 5 Old 03-30-2013, 12:48 PM Thread Starter
That's exactly what happened, the egr cooler went and the truck wouldn't even drive just white smoke so I had the studs head gaskets everything done. I am going to get back in contact with the guy that did the work and see what he says as he was meant to have cleaned the turbo as part of the deal. I figured today if you Wot it then get straight on the power it's when it does it. How hard if he won't is it to take off and take apart and clean??
Phi1 is offline
post #4 of 5 Old 03-30-2013, 02:47 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
It's not that hard to remove the turbo and clean it.
There are many videos on youtube showing removal and cleaning here is a good informative one:
GregsSD is offline
post #5 of 5 Old 04-02-2013, 06:11 PM Thread Starter
So I put a bottle of the diesel clean stuff thru, I forget the brand but it was the expensive one, I also have been getting on it hard working the turbo hard and it seems to have cleaned up quite a lot and doesn't seem to do it now. Do you this is will have solved the issue? Maybe just slight corrosion and working the truck kind of hard has moved the vanes about and cleaned the rust off? It seems to boost really good now. I guess I am going to leave it for a week or so and see how it's going then if not I will have to take the turbo off and clean it.
Is there a special procedure to starting the truck after the turbo has been reinstalled to the truck? I read that some people have problems with oil pressure after turbo removal etc.
Phi1 is offline
