check engine light - Ford Powerstroke Diesel Forum
Old 01-28-2008, 02:30 PM
check engine light
hey guys i had a bad problem today was gonna pull the egr off check and or clean it just as p.m. couldnt get the valve out didnt want to hurt it either so left it alone when i went to leave the truck went nuts jumping wildly around 2000 3000 rpm and dumpin smoke not white took my tune out which was in there for a year back to stock and now it runs ok still flutters a bit and have a p0198 oil temp circuit high voltage have never had a problem with my truck i could really use so info
Old 01-28-2008, 02:40 PM
double check that you didnt do anything accidently to the wiring or the 2 sensors themselves that are right behind the EGR valve on the oil cooler....
Old 01-28-2008, 02:45 PM
i'll give it a check but other then just pushin the wires out the way that was about it i'll be back
Old 01-28-2008, 03:01 PM
well that connector came apart just from pushin on the wires dont make um like they use too well i feel better can put my tune back in the ole girl i was a little scared for a minute thanks marc didnt even see that connector till u said somethin
