knocking/missing and turbo noise - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-29-2013, 06:48 PM Thread Starter
Unhappy knocking/missing and turbo noise
ok i've read thur a bunch of posts and nobody else's problem sounds quite like mine. I've owned this 2004 F250 FX4 crew since she was 189kish miles young (about 8 months ago). When I first purchased it i drove it home and found it leaking diesel, took it back and they fixed some part (don't remember). When I picked it up from the shop I drove down the street and found it to have no power at all. Went back to shop and found it needed a high pressure oil pump. While there were in there I used the free labor to change the oil cooler (new ford unit I believe) and did the EGR delete kit (not sure the brand). She was running fine changed the oil and fuel filters at 195k miles and got into a 4 car pile up the next day (just bumper damage for me with a 2.5" lift/level kit). Anyway the insurance for the causer of the accident gave me a large sum of money and I turned around and bought bumpers (bondocks something or others will post up pics when they get here), a AFE stage 2 intake and a Edge Juice with CTS. After I got the intake and Edge stuff in installed them (about a week ago). I've run it a few times in each setting and put about 900 miles on the truck with them installed. Everything was fine until this morning. Fire the truck up and it sounds/feels like it is missing. This does not go away when the truck is warm. I drove the truck up the street and the missing stays constant with RPM (seems to miss faster at higher RPM) so i'm thinkin maybe i lost an injector. On the trip back i try to spool the turbo to see if anything is really wrong. Under load (foot on the break at a stop) the turbo spools but makes a crazy crackling noise and when you let off it makes even more noise out the intake (both noises are new). I drive it home and when the turbo is under light spool the turbo makes the noise (and you can even feel it doing what it is doing). I'm now scared that I broke the turbo. But that wouldn't explain the missing i wouldn't think. So i broke many things...AND it was running fine the day before (about a 200 mile trip). So i'm stuck....any help PLEASE!!!
DasBronco is offline
post #2 of 9 Old 03-29-2013, 06:50 PM Thread Starter
OH i forget to add the truck came with a 4" turbo back exhaust but I don't know who made it. Also there are no codes thrown...except for the ocasional EGR flow code (forget the number) that is for the EGR del. No other codes that would explain anything being wrong. And i looked at the injector pressure (600ish idle to above 1kish driving) and the Injector Voltage (at or just above 1 but moves a little with different RMS). I'm not so sure if these would tell me if i have a injector problem or not.
post #3 of 9 Old 04-02-2013, 06:18 PM Thread Starter
Update...just started the truck...hard to start...still has same surging/missing problem...still no coded. I noticed the lights especially the one under the hood are flickering with the motor running. In park at 3k rpm the truck is only making 2-3lbs of boost...is that normal? Not as much turbo noise tho, but I did not want to try under load for fear of breaking more stuff. I hope to have time tomorrow to remove the intake to take a look at the turbo. I'm not sure if you can tell if it is bad from the intake side or not but I guess it is worth the look
post #4 of 9 Old 04-03-2013, 07:55 PM
BOGGERBOYS's Avatar
just for the hell of it look and see if the tube from the air box to the turbo is connected and then check and see if the line from the driverside manifold to the turbo is intake? I had a similar prob on the passenger side the positive battery wire while the truck is runnin and all the lights are on grab that positive wire were it links from one red to four grey or some material lum and jiggle it see if it does any thing? mine would want to shut down and or the headlights and inside dash gauge cluster would turn off and the truck would sputter
gotta take a squirt throw some groceries down my neck and get some go-go juice
06 6oh f-250xlt ccsb fx4
17'' hello rims 265/75 nitto highway dura grapplers
viair obac w/train horn
L.E.D. big rig ice running lights
FICM reprogram
110amp ho alt
22mpg city 30 hwy
Carr light bar,
two 6''150w eagle eye kc lights
two 5''130w kc lights,
two 100w airplane lights
two yellow optimas
galaxy 959,108'' wip
glowshift gauges
sony 7'' dvd
two jl 12-w3s
1500w sub amp
BOGGERBOYS is offline
post #5 of 9 Old 04-10-2013, 01:56 PM Thread Starter
Update...I gave up after looking at everything and took the truck to Ford...#6 piston is toast and so is the cylinder wall...need a new block...ford is happy to do it for me at an estimated $17k...not too bad for a truck I bought a year ago for $14k...
post #6 of 9 Old 04-10-2013, 02:22 PM
PHYRMN's Avatar
You should be able to find a long block for 6000 or less. Or start hitting the salvage yards. Sorry for the bad news.
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
post #7 of 9 Old 04-10-2013, 03:45 PM
ouch.. look around for a used one man.
badash is offline
post #8 of 9 Old 04-10-2013, 06:16 PM
You can get a long block with ARP studs and fully machined heads with hardened seats for $4400 from Blackwater.
No, I do not work for them, nor have I ever used them, but they appear to know their stuff. There was a member here who gave a nice write-up on how they rebuild their engines. (he would not say who he worked for, he was not trying to do a sales job...)
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
post #9 of 9 Old 08-18-2013, 04:02 PM Thread Starter
update
ok guys new engine in (black water engines long block) and I went to prime the oil system (pulled FICM like suggested on here) but i'm having some electrical issues. The Edge controller doesn't show up at all...when I turn the key to the on position all the dash lights come on and the dash beeps/dings. When you turn to crank it just clicks (like a dead bat). I put a charger on both batteries for a couple hours and they are reading at 100% charge now but same problem. I noticed the dome light stays on...and when you turn it to the acc key position the radio turns on until you push the brake (accident at first) then it turns off...no brake radio works...brake on no radio. I'm completely lost. I've checked all the grounds (I think) and I'm at a loss what could be wrong.
