6L turbo - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-29-2013, 07:48 AM Thread Starter
6L turbo
2006 F350 replaced turbo and it does not working, any idea please?
koli14 is offline
post #2 of 11 Old 03-29-2013, 09:00 AM
rdaffin's Avatar
Need more info! What is not working about it?
Sent from AutoGuide.com App
2004 CCSB 4x4, blue spring, SCT , 4" exhaust, Gearhead tunes, egr delete, ELC-1, Coolant filter, ARP Studs, CCV Mod, 6" lift, 35" Toyo A/T II.
rdaffin is offline
post #3 of 11 Old 03-29-2013, 09:59 AM Thread Starter
The old one pooled out, installed new one and does not turns on, no power and gage on 0, when I unplug el. wire the white/blue smoke coming out the exhaust
koli14 is offline
post #4 of 11 Old 03-29-2013, 11:55 AM
It could be a bad map sensor, Ebp sensor, or even a clogged egr valve. I'm just throwing ideas out. Because i'm still a little unclear whats going on with your truck. Did the stock turbo have the same problem as to what you are experiencing with the new turbo ?
2006 F-250 6.0L Powerstroke, K&N intake with S&B filter, 3.5" - 5inch Mbrp Cat back exhaust with muffler delete pipe, Garret Powermax, Performance Machine Coolant filter, SCT Livewire w/Innovative Diesel Xtreme tune, High idle mod, Glowshift gauges Egt, oil temp, fuel pressure. 2.5" leveling kit, 35X12.50R17 Nitto Trail Grappler, Rancho Dual Steering Stabilizer, Rancho 9000XL Shocks.
doombugie is offline
post #5 of 11 Old 03-29-2013, 04:08 PM Thread Starter
My old turbo was leeking (oil sill inside ), was smoking white/blue smoke, when I replaced the truck got no power and not smoking
koli14 is offline
post #6 of 11 Old 03-29-2013, 04:10 PM Thread Starter
EGR valve is new, how to chek others sensors
koli14 is offline
post #7 of 11 Old 03-29-2013, 08:23 PM
85burban's Avatar
did you check connection where up pipe goes to turbo? sounds like you have a boost leak somewhere.
85burban is offline
post #8 of 11 Old 03-30-2013, 04:47 AM Thread Starter
All the connections are good, will be changing MAP and EBP sensors
koli14 is offline
post #9 of 11 Old 03-30-2013, 09:12 AM Thread Starter
Changed MAP sensor, the same story, turbo does not have a boost
koli14 is offline
post #10 of 11 Old 03-30-2013, 09:37 AM
PHYRMN's Avatar
First thing you need is some type of device that can read sensors on the fly, like a scanguage or torque app. We need to know what the MAP readings and VGT readings are. You also might want to check for a leak in the Y pipe, or Up Pipes.
2011 F350 King Ranch DRW No Mods Yet
SOLD 2003 Excursion Eddie Bauer 6.0l 4x4 | 2004 Intake | Zoodad Mod | Upgraded HPOP Cover | ARP Studs | OEM Headgaskets | Updated Turbo Feed-Drain Tubes | EGR Delete | Coolant Filter | Altas 40 | MKM Street Tune | Banks 4" CAT Back | Muffler Delete | High Idle Mod | Blue Spring Update | 6.4 Banjos | CCV Mod | Glowshift Gauges (Boost, Oil Press, Coolant Press, EGT, Volts, Fuel Press) | Rotella ELC | Rotella T6 | V/B Springs | Torque App on ASUS 10" Tablet |
PHYRMN is offline
