Another Crank no start thread lol - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-29-2013, 07:29 AM Thread Starter
I have an 06 f350, I believe I have a high pressure oil leak and I have a few questions.
My edge insight CS is showing about 400-450 psi cranking...does this number rule out anything or point toward any particular spot to check first?
Does anyone have a parts list of what to buy to connect shop air to the icp location?
for a little background...I was driving down the street, stopped at a red light and it stalled...I started it right back up no problem and drove home...Later that evening I started the truck, and drove to a restaurant. When I went to leave it was crank no start and I haven't gotten it to start since.
psd807 is offline
post #2 of 2 Old 03-29-2013, 07:18 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 581 Post(s)
Garage
2006 most like the stc fitting failed, pull the ICP and put air to it and listen for air in the rear of intake under turbo. You do have a hpo issue, look up the info in stickey on procedure on pressurizing
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
4" SS exhaust
58K Miles on it
2000 Watts of McIntosh Bliss
mhatlen is offline
