Oil leak on top of engine. - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-28-2013, 03:55 PM Thread Starter
I'm new to diesel's and I just bought a 2005 F350 6.0. The truck is stock but hopefully not for long. I have noticed an oil leak and I have traced it to the top of the engine, near the oil filter. It's not leaking from the filter but in that general area. There is oil all in that area and underneath the turbo. I have no idea what anything is but if I get some help I could probably fix the problem. Any help would be appreciated!!
jculberson is offline
post #2 of 5 Old 03-28-2013, 04:36 PM
Deer Creek's Avatar
Quoted: 51 Post(s)
How much oil are we talking about?
Ryan
Deer Creek Farm
Carthage, NC. 28327
2004 F250 4X4 6.0 Diesel "War Wagon"
SRW Crew Cab Long Bed Pushing 305,000 Miles
Running 5w-40 T6 with RevX
FICM PHP Eco Tune
Blue Spring MOD
Warren 175/30 Injectors
EGR Deleted & Studded
Dieselsite Adrenaline HPOP
Coolant Filtration System
MBRP 4" Turbo Back Straight Pipe
Bullet Proof Diesel Water Pump
Ranch Hand's Legend Front & Rear Bumpers
2" Rough Country Lift
SCT X4 Tuner
Nitto Terra Grapler 285/75/16s
Deer Creek is offline
post #3 of 5 Old 03-28-2013, 05:00 PM
at0075's Avatar
So it's in the valley? How much oil? It's normal for un maintained CCv boots to leak and cause the valley to cake up with oil and look terrible. If its an obvious oil leak it could be the hpop cover, oil cooler cover gaskets. Turbo drain tube seal? It's hard to help without a pic or more insight on exactly where it's coming from
2004 f350 6.0, 6spd, studs, 175/stock warrens, deleted, blue spring, 6.4 banjos, strait 4 in exhaust, zoo dad mod, 35s, 3.5 in lift,
at0075 is offline
post #4 of 5 Old 03-28-2013, 06:22 PM Thread Starter
I'm getting a small leak on the driveway. It's running down on the starter and I think I've traced it to the valley. It looks dirty and oily in the valley but I'm not sure if the leak is coming from there. It's not a lot of oil maybe a quart every couple of weeks. I'm new to diesels so I'm not real familiar with the terminology.
post #5 of 5 Old 03-28-2013, 06:41 PM
at0075's Avatar
A quart every couple weeks is something to be concerned about. Maybe someone else can chime in that knows more than I do. Can you tell if the hpop cover is leaking?
at0075 is offline
