oil from ccv - Ford Powerstroke Diesel Forum
post #1 of 12 Old 03-28-2013, 01:52 PM Thread Starter
oil from ccv
How much oil coming out of ccv is normal????
04 (late build) f250 King Ranch CCSB
5 inch TBE, afe intake, egr delete,
ARP head studs
Sold
04 late build cc lb fx4 lariat
4 inch turbo back straight pipe
Airaid intake
Egr delete
notimeforfakes is offline
post #2 of 12 Old 03-28-2013, 01:59 PM
at0075's Avatar
Enough to gum up all of your boots over time. It will also make a mess under the hot side cac boot at the turbo. Makes the valley of the engine a mess. Pretty normal.
2004 f350 6.0, 6spd, studs, 175/stock warrens, deleted, blue spring, 6.4 banjos, strait 4 in exhaust, zoo dad mod, 35s, 3.5 in lift,
at0075 is offline
post #3 of 12 Old 03-28-2013, 02:21 PM Thread Starter
But I have a LOT of oil coming out. I am also trying to locate a hpo leak so I am wondering if it must be underthe druvers side valve cover
ARP head studs
Sold
Airaid intake
Egr delete
post #4 of 12 Old 03-28-2013, 03:21 PM
I don't think an HPO leak will contribute much (if any) to the amount of oil in the CCV.
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
post #5 of 12 Old 03-28-2013, 04:00 PM Thread Starter
Well I have replaced everything in the hpo system and still cannot locate hpo leak. Air testing isnt helping either. Any suggestions?
ARP head studs
Sold
Airaid intake
Egr delete
post #6 of 12 Old 03-28-2013, 05:30 PM
at0075's Avatar
I'm not sure a leak in the hpo system would contribute to a leaky CCv. What makes you guess at the drivers side? Is anything leaking from the driverside head/valve cover? Is it leaking from the boots ?
at0075 is offline
post #7 of 12 Old 03-28-2013, 06:29 PM Thread Starter
I just have a lot of oil coming from my ccv. And I also have a hpo leak so I figured if oil was sqirting out of a leak on the drivers side that would be why I have excessive oil in ccv.
I am at a stand still. I have tried several times to diagnose / locate the leak and everytime I thought something MIGHT be suspect, I replaced it. I have ran it with valve covers off. I have charged ipr and applied shop air several times. Dont know what else to try
ARP head studs
Sold
Airaid intake
Egr delete
post #8 of 12 Old 03-28-2013, 06:38 PM
at0075's Avatar
How do you know you have a hpo leak?
at0075 is offline
post #9 of 12 Old 03-30-2013, 07:41 AM Thread Starter
No hot start. Starts right up cold. Icp ipr normal both hot and cold. Liw and high idle. Batteries good. Ficm good. Ince its hot..... no start. Icp 250 ipr maxed out. As she coolls down pressure while crankung climbs. She starts at about 100 degrees eot
ARP head studs
Sold
Airaid intake
Egr delete
post #10 of 12 Old 03-30-2013, 08:12 AM
at0075's Avatar
Might need a hpop. I'm not sure on this one. Nothing can ever be simple on these trucks lol.
at0075 is offline
