Bad oil cooler - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-28-2013, 07:52 AM Thread Starter
perez700r's Avatar
Bad oil cooler
Would a bad oil cooler make my degas bottle cap to leak out and would it make it smoke white until its fully warmed up
perez700r is offline
post #2 of 5 Old 03-28-2013, 11:09 AM
Sounds like an egr issue, degas cap failure, maybe head gaskets. Oil cooler would only affect operating temps of the oil as far as I know. Maybe someone else will chime in with more info.
BobD981 is offline
post #3 of 5 Old 03-28-2013, 12:41 PM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 276 Post(s)
What does the white smoke smell like? If its fuel then it might be a FICM issue. If its coolant, could be either the egr, head gaskets, or even both depemding on how long a neglected blown cooler has gone
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #4 of 5 Old 03-28-2013, 01:14 PM Thread Starter
perez700r's Avatar
Well its at the ford shop and the mechanic said that the egr cooler and headgaskets were good
post #5 of 5 Old 03-28-2013, 05:53 PM
I had those same problems a few months back. It was the EGR cooler. I installed an EGR delete and a new oil cooler.
My oil cooler was so clogged water from the garden hose barely passed through it.
Luckily I did the oil cooler even though I didnt think anything was wrong with it. I dont know if the oil cooler failing could cause your coolant to purge from the degas bottle. I think it would not though.
What happens is the oil cooler starts to get clogged on the water side. The coolant is restricted when this happens. The coolant that exits the oil cooler then gets directed into the EGR cooler. With this coolant being restricted and flowing much less than normal it allows the EGR cooler itself to get overheated. When this happens the insides of the EGR cooler tend to crack and allow the coolant to dump into the exhaust side of the EGR cooler which feeds into the INTAKE and into the combustion chamber.
When the EGR cooler first starts to go it is just a seeping of a small amount of coolant. Over the course of say overnight, there may be a shot glass or 2 worth of coolant that has seeped into the exhaust side of the cooler. When you now start the engine this coolant is burned off through the combustion chamber which may take a few minutes. That is why you have white exhaust coming out til it warms up. Warming up actually has nothing to do with it, it is just a coincidence bc thats how long it takes to get burned off.
If you have an Edge Insight CTS you can monitor the EOT and the ECT. These temperatures should be close. Over a 14 degree or something like that difference it would tell you the oil cooler is clogged.
White smoke could be fuel burning off as well, just depends on what the smoke smells like.
I hope that helps even though I did not directly answer your question.
scenarioL113 is offline
