2004 ford startes up blows black smoke the dies - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-27-2013, 08:07 PM Thread Starter
2004 ford startes and blows black smoke then dies has no throttle response is this a pcm problem
bigjeff is offline
post #2 of 4 Old 03-28-2013, 05:24 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
Does it run for a second or more when it is cranked ?
Or is it stumbling without idleing ?
I would start with the ficm voltages and fuel pressure.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #3 of 4 Old 03-28-2013, 06:43 AM Thread Starter
It will idle for few seconds but has no throttle responds and blows black smoke like its over fueling could it be the pcm
bigjeff is offline
post #4 of 4 Old 03-28-2013, 07:11 AM
When I first got my truck I had a similar issue, especially in cold starts. It wouldn't blow THAT much black smoke but it would idle really rough and would stall repeatedly and mashing on the throttle did absolutely nothing. I'd have to restart it about 3 or 4 times and let it idle for about 10+ minutes before I had any sort of throttle response. I ended up replacing the FICM and my problem went away.
E-NA6CE is offline
