Long 6.0 starts - Ford Powerstroke Diesel Forum
post #1 of 16 Old 01-26-2008, 09:07 AM Thread Starter
TXbroker's Avatar
Long 6.0 starts
Long starts, batteries are good, no codes checking with an SCT Xcal2.
With the new alarm on remote start it takes 2 seconds to start. will run for 20 and shut off?
Any idead
Paul
2005 F250 4X4 CC 6.0 FX4 Lariat
All stock
Lots of Toys, cylinder count is now 31:
TXbroker is offline
post #2 of 16 Old 01-26-2008, 09:13 AM
pinkfloyd's Avatar
Send a message via MSN to pinkfloyd
does it only do it with the remote start? if so my guess would be that. if that's not the case here's a
2002 f-250 4X4 XLT 7.3,
stock tranny
DP-Tuner F6 chip
mbrp ss 4" turbo back exhaust
diy intake with zoodad mod
3 pilllar guage setup with autometer guages Thanks Raul
valve body
boost fooler
NEXT ON LIST
torque converter
pinkfloyd is offline
post #3 of 16 Old 01-26-2008, 09:18 AM Thread Starter
TXbroker's Avatar
Yea, if I start with the key she will run no issues. Still a long start but no issues
Paul
All stock
TXbroker is offline
post #4 of 16 Old 01-26-2008, 09:41 AM
I'm having the same long start issue. Took it to the dealer, but there weren't any codes thrown yet. I was basically told it wasn't a bad enough problem yet, and would have to wait until it got worse for them to track it down and fix. It is mostly just annoying at this time, but I'm still concerned that it could get bad real fast and leave me stranded.
'07 F350 PSD CC SB FX4
'08 ECLIPSE ATTITUDE F33ASKG
'07 H-D FLTRI ROADGLIDE
'11 HUSKY TE630
'59 VERY UNDERSTANDING WIFE
______________________________________
If I passed you on the right, it means you were in the wrong freaking lane.
SoCalGlide is offline
post #5 of 16 Old 01-26-2008, 10:10 AM
bullydoller's Avatar
so it will crank for two seconds before it starts? and the turn off 20 min later?
2007 F250
6 Speed
3:73 Gears
Autometer Guages
Straight piped w/6" tip
17x10 mickey thompsons\buckshot mudders
Custom tuned SCT Xcal2
bullydoller is offline
post #6 of 16 Old 01-26-2008, 10:13 AM
the 20 minutes is probably the default ammount of time the vehical will run on the remote start. IT's so if you forgot you started the vehical it won't run until it runs out of fuel
2007 F250
6 Speed
3:73 Gears
Autometer Guages
post #7 of 16 Old 01-26-2008, 10:14 AM Thread Starter
TXbroker's Avatar
Nope, If I start with teh key it starts in 2 secs and continues to run normally,
If I use the remote sart it will start in 2 secs but shut off after 20 seconds
Paul
All stock
TXbroker is offline
post #8 of 16 Old 01-26-2008, 07:41 PM Thread Starter
TXbroker's Avatar
Problem fixed, you cant run the clifford off of voltage you have to tie it into the injector harness or tach. works like a charm now
Paul
All stock
TXbroker is offline
post #9 of 16 Old 01-27-2008, 05:06 AM
Is that because the glow plugs draw the voltage down to 11 volts for like 2 minutes after you start and the autostart is looking for 12v?
720Deere is offline
post #10 of 16 Old 01-30-2008, 08:14 PM
Send a message via Yahoo to chuckles
injector harness or tach?? please elaborate. There is a TSB about this with remote starts.
Something to do with need a tach signal amplifier.....
Intermittent Unsuccessful Remote Start and/or Stall After Remote Start:
Some trucks may exhibit a no start condition when using a remote start system. Or, the the engine may start and run for up to five seconds then stall. The start/stall condition may repeat itself up to four times without operator input. The technician should contact the Ford Remote Start Technical Hotline for diagnostic assistance. A tach signal booster, P/N 102818-2, may be needed. Broadcast Message 1722.
Chuckles
07 F350 King Ranch. SCT by Innovative!!
4" Magnaflow Turboback, Coolant Fiter System, ARP Studs, Sneaky Pipe by Elite Diesel.
chuckles is offline
