Leaking coolant... - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-25-2008, 02:13 PM Thread Starter
bigwhite6oh's Avatar
Leaking coolant...
Ive been searching all the coolant leak search results, but i cant seem to find anything similar to what im seeing on mine, so hopefully its A - nothing big and B - someone might have a solution..
noticed a small puddle under the front passenger side this morning, just enough to stain the pavement but spread to about 7 inches in diameter (after truck sat for roughly 12 hours in outdoor temps of 10-30 degrees). looked underneath and the main hose out of the bottom of the radiator seems to be trickling, so my first thought was ok, simple replace the spring clamp, maybe its worn out...but while driving today i noticed that my egt's were 2-300 degrees warmer than normal with no load on the normal roads i always drive. could this leak be affiliated with a slowly failing egr cooler? or just mere coincidence that today she was running warmer? its only the first day ive noticed the leak, so i cant really relate the leak to egt's quite yet.
as simple as i thought, or has all the egr failure reading gotten to my head
truck is an 03 6.0 with 61K. thanks for any suggestions
2003 F350 6.0 PSD
\\CC//LB\\SRW//
Silverline Cat-Less Dual Turbo Back | Innovative Tuned X3
| S&B Intake | Autometer GS series Boost/Pyro gauges | Billet grille, IPCW ultra-clear clearance lights | LED bulbs for all | external lights | Recon White Lightning | LUND SunVisor | Fog Light Mod | High Idle Mod | Zoodad Mod | CCV Re-routed | Pioneer AVIC D3 | Alpine Type S/Rockford 3way speakers | Rockford 4 Channel Amp
bigwhite6oh is offline
post #2 of 7 Old 01-25-2008, 04:12 PM
SMKSTAX's Avatar
Here's a for ya!!
RICK
97 F350 CREW CAB 4x4, 7.3 TURBO DIESEL, DIY INTAKE , TW TUNES
GRAND ROCK POWERFLOW STACK KIT W/5" MITRES
3.55 REARS, 3" DOWNPIPE, FPR SHIMMED WITH GAUGE
SMKSTAX is offline
post #3 of 7 Old 01-25-2008, 04:20 PM
raddy99's Avatar
03s arnt to bad about coolers maybe just a worn clamp as you thought. is the degas bottle over flowing ever after a hard drive?
raddy99 is offline
post #4 of 7 Old 01-25-2008, 06:46 PM Thread Starter
degas bottle not overflowing so far...well give it a couple days after tomorrow new clamp and see if anything else comes up i guess
2003 F350 6.0 PSD
\\CC//LB\\SRW//
post #5 of 7 Old 01-25-2008, 06:52 PM
check the spring clamps....we had problems with them actually cracking and failing and causing a leak....... If it was an EGR cooler it souldnt have left a puddle in the front....
mschn99 is offline
post #6 of 7 Old 01-25-2008, 07:13 PM
raddy99's Avatar
ya try the clamp hopefully all is good
raddy99 is offline
post #7 of 7 Old 01-26-2008, 08:02 AM Thread Starter
thats what i was gathering from the readings here on the org .. is there supposed to be a secondary clamp behind the spring clamp, or had the previous owner possibly tried to tighten this up once? just trying to see what i am dealing with here, if we have a repeat problem or not
2003 F350 6.0 PSD
\\CC//LB\\SRW//
