Bad FICM... Now what? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-25-2013, 09:57 PM Thread Starter
So I know I have a bad FICM. I have had the batteries checked a couple times and they pass. Should I just pony up the money and replace them or get a bigger Alt (thinking 180-200 amp) or both? The truck is a 05 with Delco batteries (unknown age.)
Thanks
jmk80 is offline
post #2 of 2 Old 03-26-2013, 04:02 PM
The Silent Service
colo_dually's Avatar
Quoted: 10 Post(s)
What is the FICM Voltage when you are cranking, and your floating Battery voltage?
This will give us the real condition of the FICM. (Assuming its the OEM 48v unit)
I recently replaced my batteries, with another set of Motorcraft. I would say keep the alternator, unless you have need for more power.
When you know its the FICM, I'd start looking at the Bullet Proof Diesel unit, 4ph or 6ph depending on where you want to go with your build.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
