puked coolant but passed pressure test???? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-25-2013, 04:11 PM Thread Starter
JustinOOO9's Avatar
Quoted: 507 Post(s)
Garage
So a while back discovered my truck puked a very small amt of coolant like less then a couple table spoons it looked like. my temps are average 184 ECT and 190-191 EOT. so i did some research and got help from you guys and did a couple pressure test with a new updated cap....
I hooked the line onto the top line of the degas bottle and never got above 11-12 psi it looked like. It stayed around 6-7 til I hit throttle hard. when I ran WOT for few mins back and fourth. so I parked and bled pressure off and it didn't seem to build anymore for the 5-10 min ride home.
2 weeks later went from Fairfield ca to Licoln CA about 1 hr and 10 min and ran it pretty hard and then the next day my friend wanted to see my coolant filter and i puked quite a bit... and my coolant lvl seemed to rise half inch from when I last marked it. maybe around 70 degrees whole day.
any ideas?
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #2 of 10 Old 03-26-2013, 05:58 AM
is your coolant level at the revised mark (does it have the new sticker?)
If no sticker the new "full" in the Min mark embossed on the bottle.
Did you take the pressure gauge off? what was the pressure reading during the puke trip?
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
post #3 of 10 Old 03-26-2013, 12:15 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
Coolant will expand. As well, the hoses will flex to affect the level to a lesser degree. If you had a bubble in your top hose, that would affect your level as the temp changes.
Besides a bad HG or ruptured EGR cooler, the puking might have been a flash boil at the EGR cooler. This can happen when you stop after running it hard. If there is enough pressure created, you will get some puking. As previously mentioned, the level in the degas needs to be on the new low side.
Seems like your thermostat is failing with the low ECT.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 10 Old 03-28-2013, 09:20 PM Thread Starter
JustinOOO9's Avatar
Quoted: 507 Post(s)
Garage
so when the puke first happened I put a mark about 3/4in below the ONE line on my degas bottle (I only have one???) and even with the puke it did a few days ago it looks like its not even below the line.
1. I was not running with the pressure test the 2nd time it puked.
2. I dont think I have a bad egr assuming so at least only about 1.5k on a BPD egr cooler. and about 2 yrs on oil cooler.
3. Im getting the guy who does most installations for MKM Customs (sinister diesel) to do a couple of test on Saturday hes very knowledgeable and very polite with all my questions.
I attached a pic of my current coolant level anyone think its to high or? I only have one mark on the bottle.
Name:	coolant level after puke.jpg
Justin,
post #5 of 10 Old 03-29-2013, 05:06 AM
the level looks OK, maybe just a tad high.
MikeB
PSDMikeB is offline
post #6 of 10 Old 03-29-2013, 05:17 AM
Blue Goose's Avatar
Are you monitoring the engine? I had the same issue with mine when it was stock, but when I got my insight and started monitoring it I found out that I was having "flashboiling" moments where my alarm would start screaming and the ect was at 235* but only for 8-10 seconds and then all would go back to normal temps. The factory gauges in the dash would never move from the "normal" position when this would happen, I had a ruptured egr and blown headgaskets.
06 KR 250
Blue Goose is offline
post #7 of 10 Old 03-29-2013, 05:38 AM
Quoted: 46 Post(s)
I could be mistaken, but usually the flash boil only happens after you are shut down or if you had really high EGT and slow moving coolant (clogged oil cooler or EGR cooler). I guess if you had an air pocket in the system that could contribute to it as well.
Frank
Working for Toys
post #8 of 10 Old 03-30-2013, 02:40 PM Thread Starter
JustinOOO9's Avatar
Quoted: 507 Post(s)
Garage
had the tech who installs sinister diesel stuff run a headgasket test... im at 21.5psi so im doing headstuds, and new oil cooler but cash is tight so i gotta use credit card for the bulk of it. anyone know cheapest place to get arp headstuds, and oil cooler? im gonna do a vc-9 and restore plus flush and kill my current oil cooler and clean out all the gunk...
also i have a 04 new turbo with 1800ish miles for sale did the 03 turbo swap lol.
thx for all the help everyone now just price hunting for studs
Justin,
post #9 of 10 Old 03-30-2013, 06:46 PM
Quoted: 46 Post(s)
Thanks for the update. I guess the pressure test you initially did was off the mark.
Frank
Working for Toys
post #10 of 10 Old 03-30-2013, 06:58 PM Thread Starter
JustinOOO9's Avatar
Quoted: 507 Post(s)
Garage
lol you're tellin me. thx for all your guys input though everyone has been very helpful with all my questions and I try to share what I learned with ppl that ask me.
my roommate wants a 6.0 bad becuase he says 7.3's are to sluggish for him so we know what to look for in a used one now haha.
thanks again.
Justin,
