Helllllppppp!!! TECHS help me - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-25-2013, 04:41 AM Thread Starter
Alright, put studs in a few weeks ago, just started driving it last week (2 days less than 5 mi each day), noticed that I had a intake manifold gasket that had split and caused a pretty nice space between intake man and head. Well replaced the gasket and got everything all sealed up nice. Well in the process of putting the map hose back on I slipped off the front bumper and broke nip off of map sensor. of course I took for a test drive adn she drove like $h!T. Replaced MAP sensor just about 10 mins ago, could barely get truck to crank, could be cause of coldness but i doubt it.
She builds a lot of boost now in the low speeds like 25# and is very sluggish to take off, almost as if there is no boost but i'm reading boost on my monitor. Engine still seems a little off almost as if there is a wierd stutter in the exhaust. the engine itself sounds fine, no pops, misses or anything just the exhaust. SHould I undo the batts and let the computer relearn the turbo press and adjust for the new sensor???
- 2006 F250 Lariat 4x4 CC - Torreador Red
- EGR Delete, 5" Exhaust, ARP Studs c OEM HG, High Idle Mod, 4.5" Lift, 35" tires, Coolant Filter c ELC
scmedic85943 is offline
post #2 of 5 Old 03-25-2013, 06:21 AM Thread Starter
Alright nvm, i think i found the major issue, apparently had a FICM connection loose from pulling and moving the injector harnesses to get the intake manifold off causing low ckt codes on cyl 3 & 8. I snugged those up did a vgt relearn and voila!!!
If i knew how to delete this post to keep from showing that I learn from mistakes I would.
post #3 of 5 Old 03-25-2013, 06:39 AM
Quoted: 6 Post(s)
All good man, learning is what keeps us moving forward. Life would be pretty boring if we never learned new stuff!
05 Extended Cab FX4
SCT w/ Gearhead Tunes
Ble-Blah mod...
Edge Insight CTS w/EGT
PHP Tuned FICM-Hercules
a2elvis is offline
post #4 of 5 Old 03-25-2013, 02:22 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
Your not the first with this, and you won't be the last. The problem is, someone could have said to check the harness, and you might have said you did twice, but sometimes the 3rd time is lucky.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #5 of 5 Old 03-25-2013, 03:05 PM
Slacker
Evil Eye's Avatar
Quoted: 219 Post(s)
Feedback Score: 4 reviews
Originally Posted by Evil Eye View Post
Circuit low codes are related to the FICM and you might also have a cylinder 5 low error as well... Those are all common to the middle connector on the FICM and probably just wasn't seated correctly. Get that middle connector snapped back onto the FICM and see what she does. Keep us posted.
I did offer this advice to him yesterday morning...
From this other thread he started... Turbo Leak
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
