Injectors..... are they bad???? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-24-2013, 06:20 PM Thread Starter
I have a 2006 F250 with 95K on it. If it is over about 60 degrees when I start it there are no problems. If it colder then that it will blow white smoke for some time until it warms up. This morning it was about 12 degrees when I started it. It wasn't plugged it and it made a huge cloud of white smoke for over 5 mins. It also sounded like it was missing for about 3 or four mins. I was thinking of having some warren 155's installed but I'm a little short on funds. Should I bite the bullet and do the injectors or just wait the stock injectors out?
2006 F-250 Crew Cab. Black. Blue spring kit, EGR Delete, SCT tuner
tinmanb1b is offline
post #2 of 9 Old 03-24-2013, 07:00 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
For a bit of your time and new seals give the fix in my sig a try.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 9 Old 03-25-2013, 07:53 AM
Sounds like FICM is going out. Have you checked voltage?
MikeB
2005 F-250 6.0L, crew cab, long bed 4x4
completed in 2011: STC update, new IPR, BPD EGR cooler, oil cooler rebuild, 6.4 banjo bolts, blue spring update, SCT X3, Insight CTS, 58V FICM, CCV Mod, DIY coolant filter (now gone), refinished turbo
2012: ARP headstuds, OEM gaskets, standpipes and dummy plugs
2015: XDP coolant filter
PSDMikeB is offline
post #4 of 9 Old 03-25-2013, 11:49 AM
RAMAIRIII's Avatar
I have a 2005 f350 ccsrw and I think I lost #8 injector since my edge shows the code for low contribution. Truck idles rough and blows blue smoke. I just bought 4 remans. but was wondering if ur stiction solution would work on an injector that sounds like it's totally out?
Sent from AutoGuide.com App
RAMAIRIII is offline
post #5 of 9 Old 03-25-2013, 11:54 AM
RAMAIRIII's Avatar
Also forgot to mention last week my miss started out and my edge said it was #6 low contribution code but it has since cleared.
post #6 of 9 Old 03-25-2013, 12:36 PM
Quoted: 46 Post(s)
You never really know the condition of an injector until it has been removed. If it is stiction in any of the movement points it is possible to fix, but not always. Contribution codes can be caused by lots of things, but injectors are the most likely. If 4 or more were acting up, then the FICM would probably be at fault. However, FICM voltage would be a given to check before digging into the engine.
Frank
Working for Toys
post #7 of 9 Old 03-26-2013, 04:31 PM Thread Starter
ficm shows good on my on my sct livewire so I don't think it is the ficm. Something strange happened today. I have noticed that while I have my truck tuned it runs a little rougher and blows more white smoke then when it is on stock tuning. Today while I was warming it up after work I revved it up a couple times. It died after I revved it and would not start again until I put it back to stock tuning. Could it be the tuning and not the injectors? It is just the street tune from innovative. This one has me baffled.
post #8 of 9 Old 03-26-2013, 05:01 PM
Quoted: 46 Post(s)
You need to tell us what the true ICP/IPR is when it dies. Let's rule out the easy stuff first. It is quite possible an injector is failing open. A tune will almost always make injector problems worse.
Frank
Working for Toys
post #9 of 9 Old 03-26-2013, 06:47 PM Thread Starter
I'm new to the compression ignition world and the 6.0. I have heard about the ICP/IPR before but I don't know what they are. I think I have seen them on the tuner while playing around with it. It has only died that one time. The thing that made me think that my tune was messed up somehow is that it wouldn't start again after it died. It would turn over and even sounded like it wanted to fire but it wouldn't stay running until I put the stock tune back on. I enjoy reading this forum and have spent hours reading posts and have never hear of anything like this. The truck is running fine now and I will play around with the tuner in the AM and see if it acts up again. Thanks for your help. I will keep you up to date either way it turns out. Thanks again.
