04 6.0 leakin oil - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-24-2013, 05:03 PM Thread Starter
ace3707's Avatar
04 6.0 leakin oil
I have an 04 6.0 and its leakin oil pretty good off the driver side, but all the gauges read perfect and the truck runs perfect. Hasn't missed a beat, runs absolutely perfect. Haven't had the chance to crawl under it cause its been poorin rain. Any ideas?
ace3707 is offline
post #2 of 4 Old 03-25-2013, 06:45 PM
Check your cac tube where it goes from the valve cover to air intake elbow or it might be your glow plug o-rings.
03 f-250
blue spring
4inch turbo back exhaust
egr delete
MTW HYBRID
SCT livewire
scan gauge w egt
zoodad mod
fuel press gauge
225,000 miles
155/stock holder diesel
tatertot is offline
post #3 of 4 Old 03-25-2013, 06:52 PM
dnf12908's Avatar
Quoted: 32 Post(s)
Check your ICP sensor and pigtail connector. These sensors commonly fail and leak oil.
Darrell
'03 F-350 6.0L C/C SB FX4 SRW
SCT X3 w/tunes by MKM
MBRP exhaust-turbo back
EGR delete
ARP studs
OEM gaskets
ELC coolant & filter
MTW Stage 1 turbo w/billet wheel
FPR (blue spring)
'04 upgraded front cover
BPD fan clutch adapter/w 7.3 fan
stator delete
All-aluminum intercooler(upgraded OEM unit)
Amsoil bypass oil filter
Insight CS monitor
Harley headlights
2008 rear diff. cover
EnviroSave powertrain treatment,
dnf12908 is offline
post #4 of 4 Old 03-26-2013, 03:08 PM Thread Starter
ace3707's Avatar
It was a oil sending unit. Thanks for the quick reply
ace3707 is offline
