2003 6.0 no start - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-23-2013, 12:37 PM Thread Starter
2003 6.0 no start
Need help, 6.0 2003 no start, starts rarely cold, never starts warm. When I did get it started ICP 637, desired 637, FICM 47.92v, ICPvolt .92, 638 rpm, ipr duty cycle 25%, sync yes, FPW 1.1******KOEO FICM 48.42, bat pwr 12.48, ICP volt .15, IPR duty cyc 15%****cranking ICP 193psi, desired 1305, 48v FICM, ICP volt .4, RPM 225, IPR duty cy 85%. Pulling hair out. Thank you
RayMoody is offline
post #2 of 2 Old 03-23-2013, 02:56 PM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 274 Post(s)
Cranking ICP193psi vs. desired 1305 says high pressure oil problem. Whether its a leak, bad ipr, or failing hpop
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
