6.0 fuel issuse? - Ford Powerstroke Diesel Forum
Old 03-22-2013, 10:22 AM
6.0 fuel issuse?
I have a 05' 6.0 that wouldn't start this morning. After 2 hours it finally started. It idles fine but when I rev it up any above 1200, it just jump up and down, puffs black smoke and will not run steady. It will not even go over 5 mph. Is this a sign of a clogged fuel filter?
Old 03-22-2013, 10:33 AM
Illiana Chapter Director
Not likely. Have any way to read codes? I'd pull the EGR valve and see what it looks like.
Old 03-22-2013, 10:35 AM
The no-start sticky covers all the bases!
What parameters are you seeing on a monitor or codes?
FICM volts pre-start, during crank and running?
ICP/IPR?
Based on the puffs of smoke, it sounds like an injector issue. However, if you haven't changed them in a year, then by all means change your all your filters.
More than likely a buzz, contribution and balance test will determine which injectors are bad. Unless you own an IDS or AE or buy one, you will need to get it to a shop, if it is injector related.
Old 03-22-2013, 10:47 AM
I must have the egr deleted bc there seems to be what looks like a blocking plate where it use to be bc there are no wires going to it. Would injectors slowly go or is it an all at once thing?
