Air sound over 10 psi? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-21-2013, 07:46 PM Thread Starter
Quoted: 3 Post(s)
Hey guys, ive had a possible air leak for the past 5 months and im wondering about the possible locations of where this could be from? It sounds like its possibly from the drivers side, ive heard that its the y-pipe many times but i want to get more simple things ruled out before i go take everything apart. If it helps any, i get 20-21
pounds of boost at WOT. Thanks in advance!
Sansinga13 is offline
post #2 of 4 Old 03-21-2013, 07:54 PM
amdriven2liv's Avatar
Quoted: 4 Post(s)
Have you checked the CAC boot off the turbo? Mine was, for the lack of a better term, webbing, or shredding on the back side. It looked like mesh.
Remove it for a good inspection.
When the engine is cold, you could start the motor and quickly feel for leaks around the y pipe. I have put a piece of string on a stick and put it up near all the joints to see if a leak would blow the string around. (Flash light also needed)
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #3 of 4 Old 03-21-2013, 08:07 PM Thread Starter
Quoted: 3 Post(s)
Where is the CAC boot located on the turbo?
post #4 of 4 Old 03-21-2013, 08:38 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
BLUE, layered silicone.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
Tags
6.0 , air leak
