SQUEAKING!!
i have an 03 f250 that I had replaced the belt and one of the pulleys and it just started squeaking again... if I crank the AC it stays the same also with heat... and it doesnt matter if its warm or cold it stays the same... any ideas??! I was possibly thinking tensioner pulley? if I spray some soapy water it will stop for a little bit then it starts back up again
I have the same thing going on. I am going to replace the tensioner. Did you figure outwhat it was .
How long ago did you replace the belt? If you spray soapy water on it, goes away, and comes back, it sounds like you need a new belt.
