wine in motor - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-20-2008, 04:13 PM Thread Starter
wine in motor
i have a 2003 f350 6.0l
at ideal there is no noise under light aceration there is a high pitch whine if you acerat hard or over 8lb of boost noise goes away. When at crusing noise returns. have had to dealer they replaced mast air flow, egr, and turbo noise is still there and the same. I have put on 4" exhast turbo back still the same. this noise started about 4 months ago and acures when motor is hot or cold. also when idealing you can hear a deep exhast then will go away and goes back and forth
thanks for any help
mikef3502003 is offline
post #2 of 7 Old 01-20-2008, 04:20 PM
You know what your problem is...you're feeding it red wine, it likes white wine.
but to answer your question.....no idea.....
I'm a wh0re for free stuff
kinghawg98 is offline
post #3 of 7 Old 01-20-2008, 04:27 PM
its probably gonna be a leaking Y pipe or more likely it will be a leaking metal EGR cooler gasket...
mschn99 is offline
post #4 of 7 Old 01-20-2008, 05:13 PM Thread Starter
whine
i went over the exhast for leaks a couple of times and found none. how can i check the egr cooler gasket. this noise sounds like air is being sucked in. i also disconected egr noise isstill there.
thabk you
post #5 of 7 Old 01-20-2008, 05:18 PM
k...to do this test you will need to figure out how to make the truck do it not moving..
Rev the truck...in gear with the park brake set and your foot on the brake...till the noise starts.....get a feel for how it happens...
Then disconnect the VGT solenoid... (the connector on the turbo)...if it doesnt happen anymore its the Y pipe or the gaskets for the egr cooler...
mschn99 is offline
post #6 of 7 Old 01-20-2008, 05:30 PM Thread Starter
thank you will try that tomarow will let you know
post #7 of 7 Old 01-20-2008, 05:41 PM
The Fat Mod
Logan's Avatar
I was headed there fast, but you beat me to it
Logan is offline
