Gummed up EGR valve cause sputtering? - Ford Powerstroke Diesel Forum
Old 01-18-2008, 04:06 PM
My 03 6.0 has 170000 miles on it and has started popping back or sputtering under power. Its fine once you get up to speed and cruise. Itll smoke when this happens. Ive been told to pour tranny fluid in the fuel and that will clean it up, pull the valve and clean it up and get a new one.
What do you guys think?
Old 01-18-2008, 04:09 PM
Jon
Guest
Posts: n/a
Dont
dont put tranny fluid in the fuel. Thats not good at all. The egr is just something you unfortunatly have to deal with on a 6.0. They can get gummed up and Ford does not reccomend cleaning them like they used to. To many come backs. We just put new ones in now. Also it can get gummed up from the egr cooler going out.
Old 01-18-2008, 04:25 PM
pull it out, weld it shut then block off the cooler and walla!
I found one on Ebay part# 5c3z-9f452-aa.po404 is this the right one?
Old 01-18-2008, 04:27 PM
Jon
Guest
Posts: n/a
not sure
There are 2 diff part numbers. I dont memorize them. Sorry man.
Old 01-18-2008, 04:29 PM
NP I appreciate the help. What about unplugging or blocking off.
What does that do?
Old 01-18-2008, 04:30 PM
Jon
Guest
Posts: n/a
egr
the best thing to do is to put a new one in, let it operate normally but put a block off in the back. That works the best.
Old 01-18-2008, 04:36 PM
Thanks. Now to figure that out.LOL
Old 01-18-2008, 04:39 PM
unplugging might help but you don't wanna rely on that to solve the problem.
