please help hot no start - Ford Powerstroke Diesel Forum
Old 03-15-2013, 12:36 PM
Hey, guys. I have been getting help from this site as a guest for a while but I just signed up cause I am stumped and hope to find an answer.
I have an 04 late build 6.0 cc lb fx4 that is giving me hard cold start, hot no start snd white smoke at idle (smells like oil of fuel to me?) I am very new to diesel mechanics but am somewhat mechanically inclined. I have done the wrong thing and thrown psrts at it so far with no avail. I have no codes. I replaced hpop, ipr valve all injector o rings fuel rail orings stabd pipes dummy plugs upgrsded turbo feed and drain tubes. Blue spring upgrade all newfuel and oil filters all oem.
I have scanguage 2 and cold srart takes a few seconds then icp and ipr seem normal both hot and cold, high and low idle. But once its hot snd I try and srart it only builds about 250 pounds of pressure and thst number goes up as she cools down untill it finally hits 500 and srarts up
I have charged ipr and hit it with air and cant conclusively find any leaks
Please help. I cant afford to take it in right now
Old 03-15-2013, 12:44 PM
Oh yeah. The egr is deleted and truck has 5 inch str as ight pipe intake. 120 on the clock
Old 03-15-2013, 08:21 PM
Anyone???? I removed oil filter after I brought her up to temp and had buddy crank. Took 10 seconds to fill oil filter housing with oil so I believe I have low pressure oil
Old 03-15-2013, 08:31 PM
CAN U ACESS EOT AND ECT ?
Old 03-15-2013, 08:37 PM
USALLY HOT NO STARTS LEADS TO H.P OIL LEAK. I WOULD DOUBLE CHECK THE DUMMY PLUG CHECK ORINGS (HOPEFULLY THERE THE UPDATED ONES WITH A WHITE TEFLON ORING AND REGULAR ORING) HOW LONG DID U DO THE REPAIR BEFORE ISSUES OCCURED?
Old 03-15-2013, 09:00 PM
sounds like a classic high pressure oil leak, although 10 seconds to fill the housing seems a bit long (no idea what is righ though).
You replaced the HPOP? so I assume it came with the new fitting to replace the STC fitting?
May want to throw a gauge on the low pressur eoil and very that is adequate. Other than that it sounds like a leak. May want to repeat the air test.
MikeB
Old 03-16-2013, 06:28 AM
Thank you so much for the responces. Yeah. I am thinking its a leak too. The question is where. D plugs and standpipes are brand new updTed with the tephlon washers
My last effort (I hope) is to pull the turbo and check the o ri g where the discharge tube meets the branch tubes. That is the only oring in the entire hpo system that I hav3nt replac3d. I will keep you posted.
Old 03-16-2013, 10:30 AM
Anybody know how to remove discharge tube from branch tubes???? (
Old 03-16-2013, 12:06 PM
Powerstroke Techie
Feedback Score: 3 reviews
it's a quick connect fitting, there is a special tool but it's not necessary. two small flat bladed screwdrivers can be used to release it.
Old 03-16-2013, 04:23 PM
Thanks but I apppied air to the top of the discharge tube and cant hear any leaks. System seams to be air tight???? Anyone????
