truck died while driving wont start just cranks
05 f250 SD
135,000 miles SCT programmer EGR delete arp studs sinister coolant filter I have had a speedo problem when speedo quit it would put truck in limp mode but I think I got that straightened out I was driving down the street 35mph gave it a little gas, heard a little pop and it bogged let off and it idled for a sec then gave a little gas and it bogged let it idle down and it died. So I put in neutral and tried to restart while rolling and no restart just cranks. Towed it home just cranks no start or even hint of starting. I have checked all fuses checked for fuel in filter while cranking I have no oil pressure at all unhooked ICP sensor and it still just cranks, no start batteries are newer and kept on a trickle charger at all times, because the truck is not driven much I read the codes and got the following: P0500 speed sensor - from when i had speedo problem P0623 gen lamp circ? -changed some bulbs in gauge cluster recently P2199 IAT and IAT@ -sensor from trouble shooting limp mode problem with speedo P2285 ICP pressure low -from this no start problem u0155 instrument communication lost -from changing bulbs and speedo trouble shooting u0100 Lost communication with ECM/PCMA -from changing bulbs and speedo trouble shooting??? cleared all codes and cranked over and I still get the U0100 code -read might be from programmer returned to stock and cranked it over only codes I get now are: P0403 and P0405 -EGR delete hooked my scangauge 2 to it and checked ICP, IPR, FICM main power(FMP) and FICM low power(FLP) here is what I got Key on: ICP 0 IPR 14.4% FMP 48.5V FLP 11.5V while cranking: ICP jumped to 31 then dropped to 1-0 IPR 77.6% FMP 48.5V FLP 9-10V also checked the low oil pressure regulator and it was not stuck from reading I am thinking the SCT fitting on the HPOP? what do you guys think? |
thats a good place to start. prone to fail more suddenly than the oring in the standpipes/DP.
Did you replace the standpipes and dummy plugs when you did the studs? Should be easy enough to diagnose with an air test. MikeB |
IPR @ 77% says it all most likely stc as stated above.
I replaced the stand pipes when I did the head gaskets, but not the plugs. The stand pipes were in the kit with the head gaskets. I pulled the filter and cranked it over and I have oil to the filter, so the LPOP must be ok. I ordered the STC updated fitting kit.
Put in the new dummy plugs too, crazy that International used that style of fitting to begin with out of hpop stupid is a better description they should have been sued for that alone !!
Ok I pulled everything apart to get to the STC fitting, but it looks good to me?? I think the pump was replaced before I got the truck, must have updated the fitting too. What now?
[IMG] [/IMG![]()
The IPR valve has no screen on it?
I put it back in and screwed it back out and no screen? I put my finger in the pump hole and I can;t tell if its in there or not? Is it normal that the screen comes off and stays in the pump? |
Ok got the screen out and it is clean
Ok I did the air test, when I put air the ICP and use a funnel to listen, I only get a very faint slow oil gurgle sound from the turbo supply line hole. When I apply 12v to the IPR the gurgle stay the same very faint and slow????
The hpop and IPR were both replaced 4/27/11 by a shop just found previous owner receipt.
