2006 F350 6.0 won't start even with ether wont - Ford Powerstroke Diesel Forum
Old 03-13-2013, 05:50 AM
Exclamation 2006 F350 6.0 won't start even with ether wont
I've been pilaging through all the threads and need some help! I have checked all fuses,ficm 48v,fuel bowl full,batteries charged,unplugged icp still no fire,oil pressure comes up to 3/4 on cranking engine, replaced crank sensor no change? Checked all engine grounds ok.....don't have any gauges have cheap scanner that is showing no codes?
Old 03-13-2013, 07:30 AM
Don't use ether, period!!!
Your dash gauges are useless for diagnosing any problem.
Get a Scangauge ll or better (DashBoss, CTS, Livewire or AE (if you really want to fix something) or just tow it to a shop. Read the posts below yours. Read the sticky for no-start.
Once you have some usable data report back.
