Hey guys, just joined up. I recently bought a 2006 F-350 with 126,000 on her and I'm having some issues. I've done quite a bit of reading so far, but I'm really trying to pinpoint my problem before I throw money at the truck. The truck is studded, egr delete, with 5in straight pipe.
When I bought the truck everything was fine. Was having some issues with the heat working, so I checked the coolant. It was a little low. So I added some.. and it started puking it out. Figured maybe I just over filled it. Before this I was having what seemed like a misfire. (injectors need replaced) Took it to a shop like 3 minutes after filling it up with a coolant, they came back and said the head gasket was blown because it puked coolant after let it idle up to temp... I was leery, especially after he handed me the quote to fix it which read $8371.00 total... WTF right?
So, I took the truck home.. checked the coolant level, it was at the min mark. Cleaned up the degas bottle around the cap and went out and drove the truck. It's not puking coolant.. but there is a tad bit seeping out from around the cap. (The shop replaced the cap, so its a new cap) I haven't really lost much coolant besides when it's parked it seems like I have a leak somewhere middle to driver side of the truck. The truck hazes a greyish smoke at idle sometimes and when you accelerate at WOT. It's not a solid white smoke. Sometimes, not very frequently I hear a high pitched whistle noise when the truck gets in boost around 20lbs or so. It does it rarely...and it sounds likes its more from the passenger side. I replaced the rubber boots that goes into the turbo, it was junk. Still hear the whistle rarely.
I'm just trying to figure out whether or not I have a head gasket issue or not. What threw me off is that the truck has had head gaskets replaced once since it is studded. The egr is deleted.. but the egr valve is still there.
I'm just looking for some help on figuring this out. This is my first diesel truck, I love the truck, but not really looking to dump more money into the truck that I paid for it.
Any ideas? Is it possible something else is causing my problems? Is it possible for the egr delete to cause this still? It looks similar to sinister's delete kit. Like I said, this is my first diesel, so I don't know much about them.. besides all my friends are giving me hell for buying a Ford. Help me!
