Pretty sure fuel pump, wanna make sure - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-12-2013, 11:28 AM Thread Starter
powerstrokecrzy's Avatar
Quoted: 228 Post(s)
2003 6.0. No start. Just got done doing egr delete, ipr valve, and an injector. Wouldn't crank before the work and still won't. When you turn the switch on you can hear the fuel pump running, but it's not pumping anything. The top fuel bowl does not fill with fuel. While the pump is running and you look in the fuel bowl it will occasionally push a little into it but not much. Anything else to check? What you guys think. Yes, motorcraft filters.
Sent from my DROID X2
05 250. Lariet. 4x4.
arp studs w/oem gaskets & all updates
Warren 175cc/stock sticks
Egr delete
Zoodad
New oil cooler
Coolant filter w/ zerex ec-1(homemade)
4" turbo back, straight piped
SCT livewire (running TSD SPD)
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Ccv reroute (dump to atmosphere)
Air Horn Kit
high idle
Pro comp "bullet hole style" 17" w/ 35" nitto trail grapplers
powerstrokecrzy is online now
post #2 of 9 Old 03-12-2013, 03:20 PM Thread Starter
Quoted: 228 Post(s)
Re: Pretty sure fuel pump, wanna make sure
Somebody got to have some experience here
Sent from my DROID X2 using AutoGuide.Com Free App
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
post #3 of 9 Old 03-12-2013, 03:49 PM
jesilvas's Avatar
Quoted: 2 Post(s)
How much fuel is in the tank?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 9 Old 03-12-2013, 04:13 PM Thread Starter
Quoted: 228 Post(s)
About half tank
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
post #5 of 9 Old 03-12-2013, 04:24 PM
jesilvas's Avatar
Quoted: 2 Post(s)
I'd think that'd be enough but you might wanna fill it full to be sure.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 9 Old 03-12-2013, 04:31 PM Thread Starter
Quoted: 228 Post(s)
Yea surely 15-20 gallon should be plenty.
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
post #7 of 9 Old 03-12-2013, 07:43 PM
04cr450's Avatar
sounds like the fuel pump to me... or a bad restriction in the supply feed.
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #8 of 9 Old 03-12-2013, 07:48 PM Thread Starter
Quoted: 228 Post(s)
That's what I was thinking could be a possibility. What would be the best way to check that?
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
post #9 of 9 Old 03-12-2013, 10:01 PM
twoicebergs's Avatar
Quoted: 43 Post(s)
Blow the lines. Hook a suction device to the fuel lines from the tank. It should not have not create too much suction (Inches of mercury) - I just can't remember the number off hand, but 2-5 comes to mind.
For the pump, you could run it separately out of the vehicle. My best guess is it is you pump or a blockage in the HFCM.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
