Hpo leak? can it cause dead throttle?
I have ses wrench light on and no throttle. Codes are P0237 and P2285.
I have changed map sensor, Icp sensor and pigtail, now looking for o-ring damage on hpoi rail. Would this cause a dead throttle situation. |
accelerator pedal, try beating /tapping on the sensor that is on the pedal
I woulda looked up those codes.
P0237 Turbo/Super Charger Boost Sensor A Circuit Low P2285 Injector Control Pressure Sensor Circuit Low However, I don't think that would have caused no throttle response at all. Usually that is the throttle position sensor. |
The accelerator / tps was my first thought without pulling codes. Therefore the first part I changed. Key on not running these 2 codes will not clear so I don't believe it is mechanical
