Oil Filter Leak? - Little help here! I'm LOST! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-14-2008, 05:03 PM Thread Starter
russgriffin's Avatar
I have a small oil leak; dribbles a few drops every time you turn off the engine. I thought it was coming from the front of the block; but it appears now it may be coming from the top....
I'm new to my truck, only had it a couple of weeks; so work with me! I believe the oil filter is the tall black vertical cylinder on the top of the block?..... There is also another shorter black cylinder that is forward and left of the aformentioned.
It appears oil is leaking from the smaller of these black devices?... I say this becasue when I open the hood I can find oil on the inside of the hood directly above these two filters; there is also oil on the metal housing that the smaller cylinder screws into to.
Any ideas why this might be?
Thanks Friends,
Semper Fi
Russ Griffin
2005 F350 4X4
Crew Cab Lariat
V8 Powerstroke
Undercover Tonneau Cover
Auxillary Input Mod - iPod Connect
Future Mods:
K&N
Exhaust
Semper Fi
russgriffin is offline
post #2 of 4 Old 01-14-2008, 05:13 PM Thread Starter
Ok, I think I've figured out that's the secondary fuel filter.
Do you think that the "Oil pressure test port" at the base of the oil filter could possibly be leaking or "spraying" oil vertically? I can't think of any other lubrication parts in this area, unless you can have the oil filter itself leak?
Thanks for any help.
Russ Griffin
2005 F350 4X4
Crew Cab Lariat
V8 Powerstroke
Future Mods:
K&N
Exhaust
Semper Fi
post #3 of 4 Old 01-15-2008, 02:15 PM
npccpartsman's Avatar
Quoted: 5 Post(s)
It's possible the cap isn't screwed on correctly or someone was lazy and didn't change the oil filter o-ring. There is a new one that comes in every oil filter package and should be changed every time. It's also possible that the cap is cracked. You should be able to see an oil leak from that area with the motor running. Sometimes a bright light helps OR you can get oil dye and use a black light to find it.
I Bleed Razorback Red
Ford Makes It, International Shakes It, Casserly Fuels It, KC Turbo Spools It, SCT Tunes It, and Trucks Unlimited keeps her Rockin the Road
npccpartsman is offline
post #4 of 4 Old 01-15-2008, 05:09 PM
Hayman's Avatar
With the parts man
Pat
2006 F350 CC
SB Beige
4"409 SS 5"Tip
2 1/2Leveing Kit
Line X Bed
Hayman is offline
