injector out
I have an injector out. anyone ever run an injector from o'reillys? Or where should i get one from?
thanks for any help
Good luck with that. I would only run OEM injectors from either alliant power or ford remans if your staying stock.
Re: injector out
I have one from oreilly in my truck right now
It took three tries to get a good one. Sent from AutoGuide.com Free App |
where the other two bad? Or what? Where should i look to get one,or should i just get a set? thanks
Re: injector out
My dad has put 2 from orielly in his and they have been fine. Just put another in today, hopefully it's good, didn't get it all back together today. Well find out tomorrow.
Sent from my DROID X2 using AutoGuide.Com Free App |
Re: injector out
injector out
I may have to try one. They had two in stock just down the road. Thanks.
BWD is the subsidiary of SMP corp. The 67528 injectors have a 3 yr warranty, if installed by a certified installer. Similar to Alliant, they remanufacture as required. One might argue Alliant uses more new parts, but is it myth or fact?. Most of the new parts are usually nozzles and spool valve parts. One difference, I believe, is Alliant uses Siemens nozzles. Knowing why an injector fails helps everyone figure out what is really happening. A bad installation or an underlying problem will certainly not be fixed with any brand of rebuit or reman injector.
FWIW, I bought a mitt-full of BWD injectors to modify. I checked all the moving parts. All of the internals are very good and equal to the Alliant ones sitting next to them. Too be honest, they were identical, except for the nozzle brand. |
injector out
I called ford today. They said it was $280 for an injector. O'Reillys wants $225. For $55 more I think I will go to ford.
injector out
Went to ford today to get an injector. The parts guy must of had a good night last night. I got the injector and stand pipe for$225 no core. Works for me.
