Fuel Pressure KOEO? - Ford Powerstroke Diesel Forum
Old 03-09-2013, 05:18 PM
Fuel Pressure KOEO?
Is this normal?
http://youtu.be/xXTHkiHvaqk
Sent from AutoGuide.com App
Old 03-09-2013, 05:31 PM
No. It is probably the relief port in the regulator. Without knowing where the sound is coming from it is hard to diagnose. If it is coming from the pump, then the pump is starting to fail.
Eventhough the pump will restart when cranking, always start your truck with the fuel pump running, even if you have to cycle the key.
Old 03-09-2013, 05:45 PM
Fuel Pressure KOEO?
Just installed new fuel pump today.
Sound is coming from fuel filter area on top of engine.
Do I need to replace the regulator?
Already has the blue spring.
Old 03-09-2013, 06:17 PM
Take your regulator off and check your blue-spring installation. It might just be a pinched o-ring. Make sure all the parts are installed correctly.
Old 03-09-2013, 06:26 PM
Fuel Pressure KOEO?
Will tear it apart in the morning.
Thanks.
Old 03-09-2013, 10:04 PM
Fuel it up again Dummy
^^Yep I agree^^
Old 03-10-2013, 05:35 PM
Fuel Pressure KOEO?
Looks like I may two issues.
Not a blue spring (doh) and the o-ring looks compressed. Fuel Pressure KOEO?-imageuploadedbyautoguide1362965695.346466.jpg
Ordered new kit. Should be here in a day or two.
Old 03-10-2013, 07:31 PM
Yes the o-ring looks damaged. Also look to the top of the other side and check the white clip and o-ring.
Old 03-10-2013, 07:40 PM
Fuel Pressure KOEO?
You mean the white plastic piece?
Old 03-11-2013, 07:42 AM
Yes, that looks good.
