wrench symbol (electronic throttle control) - Ford Powerstroke Diesel Forum
Old 03-07-2013, 01:13 PM
Question wrench symbol (electronic throttle control)
05 6.0 lt runs good but one issue I cant seem to get around is this wrench symbol that pops up under high turbo boost conditions! I have had a diagnostic comp hooked up to try and capture a code and it shows nothing but the wrench light on the dash. . wont surpass about 18-20 psi of boost. Pull over, power down, power back up and off to grannies. most of the time it occurs, i am towing, but can make it happen climbing hills empty (my foot into the throttle) seems i can manage if i continually monitor the boost gauge but dodge chevy and other fords with similar loads are leaving me in the dust . Ford dealership has no express knowledge of this and tell me i need to bring truck into dealer ship with wrench light on. HELP!!!!
Old 03-07-2013, 02:25 PM
Do you have a monitor in your truck. I suspect your you oil cooler is clogged and it is throwing the wrench for your coolant and oil temp delta being too large.
Old 03-07-2013, 02:51 PM
no monitor on board new oil cooler installed when original egr packed it in 90000 miles
mabye lines clogged? had factory hand held monitor plugged in on a trip to see if I could trap a code or ? but nothing showed up each time
