Coolant Change - Ford Powerstroke Diesel Forum
Old 03-07-2013, 10:22 AM
Coolant Change
How often do you change coolant? How often do you need to change fuel filters?
Old 03-07-2013, 11:12 AM
Depends what coolant you are using. Fuel filters must be changed at 15,000 miles using only FoMoCo
Old 03-07-2013, 03:40 PM
Fuel it up again Dummy
^^ that is correct^^ many of us go 10K and if you are using the Ford Gold coolant I would not go any further then 25,000 miles or 2 years (whichever comes first).
Also a coolant filter is money very well spent to keep the cooling system from plugging up the oil cooler.
ELC you can comfortably go 5 years with it, if you are severe duty: pulling heavy on regular bassis you may want to do it sooner.
Old 03-07-2013, 03:51 PM
And if you are running Ford's Gold, make sure your adding SCA's
Old 03-07-2013, 04:38 PM
What is SCA's?
Old 03-07-2013, 04:44 PM
SCA: Supplemental coolant additives. For a diesel, these are needed to combat cavitation. Diesel rated coolants come pre-charged with SCA's. cavitation is formation of microscopic air bubbles in the cooling system which can, believe it or not, eat the block itself. Friend of a friend was running regular green in his 7.3 and it ate a hole in one of his cylinder walls. Just the nature of the beast
Old 03-08-2013, 06:22 AM
Thank you. I add Kool Aide to my yellow coolant.
Old 03-08-2013, 06:26 AM
punch in your year here if you don't have a manual
https://owner.ford.com/servlet/Conte...e&ord=49262630
