how do you replace a cam sensor and
crank sensor on a 6.0? any body know?
tia |
crank position sensor or camshaft position sensor?
These are basically bulletproof. Why are you replacing either one? Did you have a long crank to start and the PCM threw a code? You should really look somewhere else before you replace either one.
FYI--they are just held to the block with one retaining bolt I believe, but they very very rarely go bad. |
Yes
8mm bolt on each. Very rare to have one give a problem other then the orings leaking. Very common though to throw a code for them when other things are happening.
i sank it awhile back--it was sputtering above 2000 rpms so i assumed it was mass air flow but codes said it was crank and cam sensors--so i attempting to remove cam shaft sensor and put it back in as i had to pick up kids from school--well the truck rund perfect no but engine light is still on....does it have to be cleared for light to go out?
