Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Motor problems
Old 01-07-2008, 03:04 PM
Stroker23 Stroker23 is offline
any ideas?
i dont know if some of you remeber
but i sank my 06 awhile back---
well ive replaced starter, alt., batteries,and a complete detail but i still have a problem....
well 2 actually....
1. the truck backfires or pops if you will under a load(anything over 2200 rpms) any ideas? (maybe mass airflow?)
2. front end is locked up front diff will not disengage--in other words if i engage 4wd the truck will not move--i put back in 2wd its ok-i disconnected the front driveshaft and trans. case is ok...any ideas?
tia
Old 01-07-2008, 03:42 PM
goodriddance goodriddance is offline
1:??
2: did you pull the front diff pan after sinking it? could be full of water, or had enough water to gauld things up inside. does it clunk when you engage 4wd?
Old 01-07-2008, 03:57 PM
rankroddin250 rankroddin250 is offline
the back firing may be water in the fuel system.
Old 01-07-2008, 04:23 PM
i pulled the front diff. and it was full of water so i cleaned it and put everything back together and still doing same thing(do they have clutches like rear?).....no clunking just locks up as soon as transfer case engages...when i took the drive shaft loose i could not turn at all.
im going to replace mass airflow and see if that helps(per #1)
thank guys
Old 01-07-2008, 04:35 PM
I'm pretty sure it's an open Differential, so there shouldnt be any clutch's or LSD in the front, possibly the bearing is frozen, or some kind of damage to the u joint? is it electric or manual hubs?
Old 01-07-2008, 04:44 PM
there electric with the overide on the hub (it has been checked also-hubs)
i know its a bad idea but i thought about driving 2-3 mph and engaging to see if frees up--when i got stuck and left truck front end was working fine..there was alot of metal shavings when i pulled the cover--ahh about normal i guess for 40,000 miles-it just feel like something is bound up
ty good
