6.0 possible HPOP issue...
Alright my truck when i bought it, it took about 2 seconds of cranking for it to start i would just count 1 mississippi 2 mississippi and start. But i have started noticing that it takes much longer like 4 to 5 seconds but only when its warm, when its cold its still like 2 seconds.It just seems like it cranks over forever to start. From resurch i have done i think it could be my HPOP or the sct fitting in the HPOP but i need some help, could it be something else or any suggestion on what else to look for. Also is there a way to check the HPOP or no.
Re: 6.0 possible HPOP issue...
What oil are you running? Did this start after an oil change? Your description sounds like an o-ring on a stand pipe that is worn/torn. When the oil is cold and thick it has a harder time "leaking" past the o-ring. When the oil is hot and thinner, it has less of a problem getting past the o-ring. Not to say that it can't be something else but this sure fits your description.
I know you said that it seemed to change but it may not be broken or it may not be oil related. Sent from AutoGuide.com Free App |
It started about 300+ miles after my first oil change on the truck, and i used 15W-40 not shure what brand but my dad said he got the best oil he can and he is a diesel mechanic but he works on big work equiptment not really pickup trucks. I also did the fuel filters and oil filter and i also put a ford brand oil filter cap on the truck bc the PO had a different one on there and it was much taller than the ford brand. any suggestions i just want to know some bc i am going to call sheilds diesel which is the place that did my headstuds and 4 injectors when i called them and asked about the work done they said they did all the updates to the truck so i just want to know what to ask to see if they have fixed it already, the work was done at 118,000 and its got 132,000 on it now.
also is there any way to diagnose this type of problem?
You can introduce shop air into the HPOP system and listen for leaks. If your dad works on any CAT or International engines this shouldn't be a problem for him since they use the same bsic system on some of them. If shields is close to you it may be easier to have them look at it.
