05 Excursion 6.0 No Start today - Ford Powerstroke Diesel Forum
post #1 of 27 Old 03-01-2013, 08:20 PM Thread Starter
I parked at the bank to day for 10 minutes and when I tried to leave I had a no start condition.
I did get it started after about a half hour. I had tried cranking it every 5 minutes or before I got it going.
I have an Edge CTS and was monitoring everything. I had these reading with the NO START condition:
FICM voltage is 48
ICP 700PSI give or take
Battery Voltage over 12.5 cranking
When I got home I looked everything over and could not see any chafed wires or anything. I will look more though. The vehicle starts up evey time now but seemed like it took a lil longer than usual.
I did notice I was a lil more than 1 and a 1/2 quarts low on oil. Seems to start quicker after adding the oil but I am hard pressed to think that would cause the no start.
Scary stuff when it dont fire up and your numbers are in the green.
Any suggestions, I mean it is working now but I have a feeling it may happen again like most 6.0 owners would.
scenarioL113 is offline
post #2 of 27 Old 03-01-2013, 08:34 PM
67ModStang's Avatar
Send a message via AIM to 67ModStang Send a message via Yahoo to 67ModStang
Could be a fuel pump going bad. Any idea what your fuel pressure is?
Jered
GONE
1967 Mustang Coupe 5.4L Lightning, 2.3 Whipple, Viper T56
2011 Mustang GT 5.0 Stock
2005 F-150 Lariat 4x4
2004 Excursion EB 4x4
67ModStang is offline
post #3 of 27 Old 03-01-2013, 08:42 PM Thread Starter
Sorry
Yes my Fuel pressure 60PSI.
That is while cranking and I only drop to 58 WOT.
post #4 of 27 Old 03-01-2013, 08:47 PM Thread Starter
If I have over 700PSI oil pressure when cranking could I still have a HPOP issue causing the no start?
I am no mechanic but I have read and read and read forums and posts on these 6.0's. I did my EGR delete and the Oil Cooler 6 months ago, I have gotten my hands dirty and my knuckles bloodied but I am baffled on this one.
post #5 of 27 Old 03-01-2013, 08:48 PM
67ModStang's Avatar
Well, no problem there.
Only other thing I can think is that your ICP while cranking seems a little low...While it is above the 500 minimum, I usually see well over 1000 psi while cranking
Jered
GONE
post #6 of 27 Old 03-01-2013, 08:50 PM
67ModStang's Avatar
There is a thread here somewhere that has a very indepth guide to troubleshooting no starts...I'll see if I can find it and link it to you
Jered
GONE
post #7 of 27 Old 03-01-2013, 08:52 PM
67ModStang's Avatar
Here it is...
No start issue? Look here.
Jered
GONE
post #8 of 27 Old 03-01-2013, 09:31 PM Thread Starter
Thank you!
I will play with the EX tomorow and see if I can find anything. I will advise.
post #9 of 27 Old 03-01-2013, 10:06 PM Thread Starter
I forgot to mention, I did not have a check engine light but I did scan a P2285 code.
I did not clear the code but after a few restarts I thought I would clear the code with my scanner but the code was no longer there.
Kind of weird but that is what happened.
post #10 of 27 Old 03-02-2013, 07:23 AM Thread Starter
I put my battery charger on my batteries and they are showing 60%. I have 2 Optimas which are fairly new (under a year) but I must say I am not thrilled with their performance.
Both have already been replaced under warranty.
I did crank the crap out of them last night trying to get started but nothing too crazy.
I think I cranked one interval of 30 seconds and then maybe 10 to 15 intervals of 10 seconds.
When I drove home it ran for about 20 minutes.
I think the charge is a bit weak on them and prob not related to my excessive cranking. It just may attribute to Optima not making the quality battery they used to.
I will add I had dual batteries (Yellow Optimas) on our 04 Silverado 8.1L in 2010 -2011 and both had to get replaced as well because they took a poop!
Anyway, thats my deal!
