Head Gaskets & Studs...Gasket?? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 02-28-2013, 11:09 AM Thread Starter
03RaptorCV's Avatar
I want to know the necessary orings & gaskets to replace when having OEM headgaskets and ARP studs installed? I know a lot of people just replace most of the gaskets and o-rings because they have it apart, but all you experienced 6.0 mechanics out there what gaskets and o-rings do I truly need to provide the shop with to do this work properly? From what I have gathered reading a lot of threads on here and talking to a few forum members is that the injector o-rings are truly the only ones a guy has to swap.
Thanks!
2005 F-250 Lariat, SCT X3 w/IDP Tunes, Scangauge II, 4" MBRP Exhaust, Blue Spring Upgrade, High Idle Mod, Updated Turbo Oil Feed Line, ELC Coolant, Sinister Coolant Filter
03RaptorCV is offline
post #2 of 15 Old 03-01-2013, 07:47 AM
jmeaby's Avatar
Quoted: 16 Post(s)
Look up Tuscany's part list for studs in the performance section good spot for info
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #3 of 15 Old 03-01-2013, 11:07 AM Thread Starter
03RaptorCV's Avatar
Bryan's list is pretty close to what I'm getting.
Here goes my list:
250-4202 ARP HEAD STUD KIT - 399.00
4C3Z-6051-EB OEM Head Gasket Kit - 135.00ea X2
3C3Z-6A642-CA Oil Cooler Kit - 245.00
4C3Z-9B246-F STC UPGRADE KIT - 39.99
6C3Z-9T515-A TURBO DRAIN TUBE - 22.76
3C3Z-9229-AA INJECTOR ORING KIT - 3.69ea X8 = 29.52
6C3Z-9448-A EXHAUST MAN GASKET - 10.74ea X2 = 21.48
W302908 Dummy Plug - 11.96ea X2 = 23.92
Is there anything I really should get as well?
post #4 of 15 Old 03-01-2013, 11:13 AM
Korx's Avatar
IIRC, The dummy plugs are included in the headgasket set. I replaced the rocker box gasket, but I hear they are reusable. Possibly a IPR screen kit, I would replace it while you have it out.
2004 6.0L F-250 XLT - ECSB
CTS SCT
Deleted
Studded
5" Exhaust
175cc Injectors
1995 7.3L 5-Speed F-350 XL Dump
Stock
Korx is offline
post #5 of 15 Old 03-04-2013, 05:10 PM Thread Starter
03RaptorCV's Avatar
I'm pretty sure you have to buy the dummy plug update, but the updated stand pipes come with the OEM gaskets.
post #6 of 15 Old 03-04-2013, 06:48 PM
Bump To Pass!!
toren302's Avatar
Quoted: 1610 Post(s)
The stand pipes come in the gasket set. Get the valve grind set and youll have all you need to do the job and half the cost of buying the gaskets seprate. My parts list for these is usally a valve grind kit, dummy plugs, STC update kit if not done already, and oil cooler rebuild kit.
Edit: And what ever the customer wants to do for the EGR delete or BPD cooler.
toren302 is offline
post #7 of 15 Old 03-04-2013, 08:21 PM
jmeaby's Avatar
Quoted: 16 Post(s)
Since u have it so far apart how is your hpop?
04 f250 cc sb.
jmeaby is offline
post #8 of 15 Old 03-04-2013, 09:05 PM Thread Starter
03RaptorCV's Avatar
Injector Control Pressure is still really good. What else would show signs of an ailing HPOP.
post #9 of 15 Old 03-04-2013, 09:05 PM Thread Starter
03RaptorCV's Avatar
What exactly is the valve grind set? Part #? Also, Toren where are you out of in the NW?
post #10 of 15 Old 03-04-2013, 09:16 PM
Bump To Pass!!
toren302's Avatar
Re: Head Gaskets & Studs...Gasket??
I live in Monroe. Work in Duvall about 20min east if Seattle. I can get you the part number tomorrow.
Sent from AutoGuide.com App
toren302 is offline
