High - low pressure oil and no vgt - Ford Powerstroke Diesel Forum
post #1 of 11 Old 02-27-2013, 04:25 PM Thread Starter
ps_lane01's Avatar
Quoted: 10 Post(s)
My hpo system checks out great, i just replaced hpop, icp, ipr and some other parts. I also cleaned the turbo, its veins, unison ring, etc... with the turbo apart, the actuator was difficult to move between its open and closed position(maybe bad oil in the actuator?) after cleaning the turbo it still has problems changing vein positions so i took it for a long pull and i noticed the lie o meter oil press gauge went up until i let off the go pedal. There is also oil coming from the turbo return and there is a light coat of oil all over the oil cooler/ filter housing. My guess is the actuator is being plugged? Apparently there is a micron filter that is non serviceable on the actuator. Am i on the right track of replacing the actuator? Also, with hot starts it will buck and lope when idling in drive as if there is air in the system but that just happened today twice, and all air has been purged after the repairs.
Any insight would be appreciated.
Sent from AutoGuide.com App
2003 Silver 6.0L PSD CC/SB FX4
EGR Delete, Oil Cooler upgrade
Blue Spring & Banjo Bolt Upgrade
AFE Stage II Intake, MBRP Straight 4" Turbo back
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Recon Smoked Cab Lights
Recon Interior L.E.D.
Recon 3rd Brake L.E.D.
Custom Fiberglass Center Console
Two 10" Sundown Sa4's, Hifonics 1200 RMS mono
Optima Batteries
Meyers 7.5C Plow
ps_lane01 is offline
post #2 of 11 Old 02-28-2013, 01:57 AM
The vgt solenoid's oil is supplied by the LPOP and the solenoid does sometimes go bad so replaceing it is a viable option.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 11 Old 02-28-2013, 07:55 AM Thread Starter
ps_lane01's Avatar
Quoted: 10 Post(s)
The solenoid and the actuator are two seperate pieces correct? I guess what im asking is there a chance the actuator is bad as well, my bank acct doesnt like throwing parts at this truck anymore. Thanks
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #4 of 11 Old 02-28-2013, 10:12 AM
Gotca now. I have found more often that the hole in the unison ring is more often wallowed out than I have seen the lever mechanism to wear out.
But either is possible.
post #5 of 11 Old 02-28-2013, 10:31 AM Thread Starter
ps_lane01's Avatar
Quoted: 10 Post(s)
Oh ok, the slot in the ring where the half circle arm moves the unison ring? It looked a little worn out but not to the point where it would be getting caught up on anything. Is that arm supposed to be difficult to move? It was not very easy to move when cleaning, it was my first time cleaning and I dont know how much pressure is supposed to be on the piston.
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #6 of 11 Old 02-28-2013, 11:49 AM
twoicebergs's Avatar
Quoted: 47 Post(s)
If you move the lever it should move fairly easily. It will often move back by itself if you move it when positioning it as you put the turbo back together. Cleanliness is extremely important near the oil inlet as the oil goes to the VGT valve first. It could be either the ring binding, the valve or the VGT solenoid. Ford is very specific about not damaging or getting the valve and solenoid dirty.
DTS Articles - Turbocharger Reconditioning
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #7 of 11 Old 02-28-2013, 04:20 PM Thread Starter
ps_lane01's Avatar
Quoted: 10 Post(s)
Thanks for posting that article! I followed a writeup on here that was very similar. I high idled the truck and pulled the connection to the solenoid and i can tell a difference, soo the solenoid shoulddd be working correctly. I have a feeling my up pipes are to the point that it will not even hold EBP anymore. I think ill slap a solid y-pipe on there and see if i continue to have the no boost and lag issue. You can barely hear a whistle anymore :-/ Thanks again
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #8 of 11 Old 03-07-2013, 04:26 PM Thread Starter
ps_lane01's Avatar
Quoted: 10 Post(s)
High - low pressure oil and no vgt-imageuploadedbyautoguide1362705640.442568.jpg
So that was the low boost issue i was having AHHH now that that is all fixed i think shes putting out too much boost... At 50% throttle shes at 30 lbs on a light street tune, at idle anywhere between .5 and 1 lb of boost and when in park at about 2300 rpm it will continue to boost to about 5 psi. also, when easing off the go pedal(not quickly release throttle but barely easing off it) she has some major compressor surge until u let completely off the go pedal...
Sticky vanes still? I just cleaned it and unplugging the vgt does make a difference so its doing something. No overboost codes.
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #9 of 11 Old 03-07-2013, 04:29 PM Thread Starter
ps_lane01's Avatar
Quoted: 10 Post(s)
Also, i removed the vgt solenoid just to make sure the orings were good and everything looked as it should, the tip was coked with burnt oil and smelt terrible, the inside of the actuator housing was really coked up with burnt oil as well.
RBP 6" tip
SCT Custom Tuned
Autometer GS series
BFG A/T 285s
Optima Batteries
Meyers 7.5C Plow
post #10 of 11 Old 03-07-2013, 06:13 PM
Quoted: 47 Post(s)
That was one broke pipe! No whistle out of that hole.
In park or neutral at 2500rpm you should have almost no boost. What you are telling us is a sign of sticky vanes (range of motion). The actuator should just have no or very minimal build-up inside.
Frank
Working for Toys
