05 f250 starting problem
05 f250 6.0 will start just fine when it is cold after the motor reaches normal operating temp. it will not start. let it cool down or use starting fluid and it will start just fine. I have changed the fuel filters, changed the oil and filter, used injector cleaner in a full tank of fuel. Once it is started there is no power lose runs great. Any Ideas?
Did you pull any codes?
you have a high pressure oil system leak, when the oil gets thinner hot , it cant build enough pressure to start , i bet you have codes p2290 and p2291 in the pcm when you pull codes
I went and had the system checked for codes no codes
where did you get codes checked at , some places dont have a scanner that will communicate with a 6.0 , may want to get it on a better scanner
oops just saw this thread is a double post. but good to see I guessed the same thing as scuffy! lol
Went this morning and had my truck scanned with a high tech. scanner did not have and codes but the HPOP pressure was only 342psi needs 500psi plus will have this repair made this week and will update.
PICKED TRUCK UP FROM DEALER SERVICE TODAY STARTS GREAT RUNS GREAT THEY HAD TO PUT NEW LINES ON THE HPOP. THANKS TO EVERYONE FOR YOUR HELP.
glad to see you got it fixed , i thought thats what it sounded like
