quick glow plug qestion - Ford Powerstroke Diesel Forum
Old 02-24-2013, 03:13 PM
2004 6.0...build date 04/04.....the sensor that tells wether it a 2004.5 or not is by the turbo so i do not have a 2004.5...i believe icp sensor its called?
Question is do i use 2003 glow plugs that are 1.3mm longers or 2004-2007, 1.3mm shorter.
thank you
Old 02-24-2013, 04:03 PM
use the 03 glow plugs.
Old 02-24-2013, 04:14 PM
Powerstroke Techie
Feedback Score: 3 reviews
wait, 04/04 is late, very late for an 04
To clarify....Is your ICP sensor on your right valve cover by the glow plug control module? If it is you want the shorter glowplugs. ZD-13 is the motorcraft number
If you don't know what to look for take a pic!
